Help!! - Car won't start; electrical prob.
  • Thread starter Thread starter 351c-ya
  • Start date Start date Jun 21, 2004
351c-ya
30
Oceanside, CA
Jun 21, 2004
  • Jun 21, 2004
I went to go for a cruise yesterday, and when I turn the key; nothing happens. I have an MSD Digital 6 ignition, which has a red light on the top that should be lit when the ignition is on. It's not, and my electrical gauges, which usually go to zero when I turn the key, didn't. I checked the battery, which is fine. I replaced the starter solenoid; still nothing. Only thing I can think of is maybe the voltage regulator went bad? It only costs about $20; so I don't have a problem replacing that if you think that may be the problem. The ground is good from the battery. If it's not the voltage regulator, does that mean I have to go through the whole ignition wiring system? What else should I be looking at; I'm not much good with the electrical system.
Car is a 70 mach; 351C 4v. Note: I added an electric fan about 3-4 weeks ago; could this have caused the problem in any way? Car was running perfectly when I parked it on Thursday. I need to get this fixed quickly, I was hoping to go to the drag strip this Friday night.
M
mustangman70
1,235
St pete, Florida
Jun 21, 2004
  • Jun 21, 2004
Double check all connections, make sure they are clean, sand them if needed. Are the wires to the the starter and starter solinoid connected? try jumping the solinoid as it could still be bad (ive had it happen)
Yous MSD ignition has NOTHING to do with the starter trying to crank that motor, if it was the MSD it might crank but not start. You said the gauges didnt go to zero, This is like my tach, which dosent go to zero when the battery is disconnected, sounds like a bad battery to me man.
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Jun 22, 2004
  • Jun 22, 2004
if your getting no guages you have no voltage inside the car, it comes from the "+" terminal on the solinoid. It either has a bad connection there, or a bad wire from there to the fuse panel. if you have a test light check it from the solinoid and see where you are losing it.
PS. I just checked the wiring diagram and it looks like the feed from the solinoid is Black with aYellow tracer, it goes form the solinoid to the firewall connector to the interior, when it gets inside it changes color, BLK/ORG feeds the headlight switch, Yellow feeds the ignition switch, and a third wire feeds the fuse panel, but the color isnt marked on my diagram.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Jun 22, 2004
  • Jun 22, 2004
You did check your fuses right?
There is definately a power supply problem. Could be just about anything..time to get out the 12v test light and start checking your voltages. I'd start at the fuse panel.
Oh.. and it's definately not the voltage regulator.
Pakrat
3,843
Currently: NH Originally: Rhode Island (and all po
Jun 22, 2004
  • Jun 22, 2004
Are you sure you checked the ground good from the battery to the engine block? If you just put the car in acc position and not start it, does the radio still work?
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Jun 22, 2004
  • Jun 22, 2004
there are no fuses involved with what he has.
F
ForceFed70
4,818
BC Canada
Jun 22, 2004
  • Jun 22, 2004
Why do you say that? Do you mean he's already checked them? Everything is fused...
pabear89
2,126
High in the Hills of So Ca with the Voices in My H
Jun 22, 2004
  • Jun 22, 2004
Unless someone has added a inline fuselink, they were not manufactured with it in the ign system wiring.
PB
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Jun 23, 2004
  • Jun 23, 2004
there are no fuses between the solinoid and the ignition switch, so even if all the fuses were blown it would still crank and run.
N
norcalsvt
88
San Francisco,CA
Jun 23, 2004
#10
  • Jun 23, 2004
  • #10
A problem I had when the car wouldn't crank or turn over, is there was some sort of short in the shifter console. The only thing that turned on is the shifter light for the tach, other than that, nothing else. I had put a new carpet in & the B&M Hammer Shifter electrical must have been grounding out or something. After I removed he cover it started up.
351c-ya
30
Oceanside, CA
Jun 23, 2004
#11
  • Jun 23, 2004
  • #11
Sorry I posted and didn't keep up with the thread; I took the day off work yesterday to get it running and do some other stuff. Turns out the wire going from the solenoid to the fuse box had burned up and separated; so Worth, you now have "guru" status (with me, at least)!
When I fixed it, I added a fusable link so that if a short some place caused the problem, it will blow the fuse instead of causing more problems. Could it just be that the wires are old, or do you guys think I have other problems which need to be found?
Thanks again,
Lance
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Jun 23, 2004
#12
  • Jun 23, 2004
  • #12
good job adding the fuse is a plus, I don't know why they are unprotected from the factory, always sounded like a bad idea to me.
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
89 LX Electrical Troubles
  • fun331
  • Oct 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 27, 2025
fun331
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
manicmechanic007
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
