Help Clutch install Asap please!!!!
does any one have any pictures of how the fork and the throw out bearing go in. I put the tranny in and he fork was really loose!!!!! and the pedal really soft!!!! Dammit i alwyas have to run into problems
Guero, the picture that you have posted looks very similar the the opposite side of the disc in my picture. If the other side of your disc looks similar to this, then I would say that what you see in my picture is for the flywheel side (as that's what the white sticker says).
I'm also interested in pictures of how the fork and all that goes in. I know I'm tearing mine apart and should see from that, but more pictures never hurt.
The fork should be attached to the ball. The TO bearing should be up against the metal "prongs" on the pressure plate so that the bearing can rotate when the fork pushes it against a spinning pressure plate. Hope that makes sense......
Oh yeah, the TO bearing kinda attaches itself to the clutch fork by means of those clips inside the fork...kinda slide the skinny part of the TO bearing into the fork through the enlarged part of the hole.
This is assuming that the T56 clutch setup works the same as my TKO setup.
on mine mine theres alot of play between the end of the tranny to the the metal prongs...and i did intall the tob into te fork already
i got pics of the tob... thats all i rember going on there...
all i got bro
as you can tell... my TOB was toast.... all melted up... ball bearings sitting in the bell housing... good times
