o2 sensor shows lean condition on left bank.. I guess im not getting enough fuel to one side... ? what could be my problem?? thanks!
If you want, clear the code, swap your O2's and see if the issue follows the O2. If so, replace the O2.
Good luck.
Its always good to change both O2 sensors when one goes bad. The other is usually not far behind.
Im not saying that its bad, but when I had the same code, I changed them both.
