so im doing good financially now a days. and i think i am going to get some springs to lower and stiffen with my new shocks and struts. since no one has heard of the tokico springs, i guess there out which leaves me at c springs, b springs, or eibach pro kit. the alphabet springs are cheaper so lean towards those for me, unless eibachs are a ton better. pics of any of these springs is greatly appreciated. im looking for a moderate drop, and stiffened handling. not bone jarring potholes.
MustangOwner
Banned
- Dec 13, 2006
- 160
- 0
- 0
I'm running the Eibach Pro-Kit on my '91. I have never seen a better stance ever on a stang and it drops it nice. My car is a street car and has no problems. I'm getting some slight rubbing up front with my 18x9's but i've come to the conclusion its because of the Alignment. So really no problems. Remember when you lower it to get all the other crap....Camber/Caster plates, offset steering rack bushins, shorter endlinks and so on...
Heres the stance with the stock springs
And heres a picture after the Eibach Pro-kit and other stuff.
I rec. the Eibach Pro-Kit
oh dang i was thinking that with atleast alphabet springs that you wouldnt need shorter endlinks, the rack bushings, and cc plates...
i cant afford all that stuff. its nessicary right?
GT_Rich
I'm running B-springs and I'm very happy with the ride and stance. Struts are KYB-GR2's. I do not have any of the above mentioned suspension components and my alignment is fine. Fine a good alignment shop that will slot strut holes for you - it will save you some $$.
MustangOwner
Banned
- Dec 13, 2006
- 160
- 0
- 0
They way i understand it is that if you drop it enough you need to do them. Although my neighbor is running lowering springs and he is still running stock camber plates and no problems, although is a '85. Usually you have problems with alignment with out the camber/caster plates. The shorter end links are not required but it will drop the front sway bar down to where it is suppose to be when you lower the car. And the rack bushings i would do if you drop it alot. You could probably get away with not doing any of them...but dont expect it to go smooth. You could see some issues, but who knows try it out?
thats what i was thinking, that alphabet springs arent enough of a drop to need that stuff. should i get b-s or c-s?
b springs are progressive so a little softer
c springs are linear so are a little stiffer
drop is about the same so i'd go with the b's
have you tried drilling the rivet hole on the stock ones? my friend that will help me install these says that he knows how to do that. and that can help your camber.
- Replies
- 23
- Views
- 495
- Replies
- 24
- Views
- 1K
- Replies
- 8
- Views
- 507
- Replies
- 32
- Views
- 4K
