Help Diagnose what's wrong with my Subs
MineralG2k2GT
451
Lowell, MA
So I have been noticing latley that my subs are producing very little bass and absoultley no punch
My set up is 300/2 bridged to 2 JL Audio 10W6's which are about 4 yrs old
The amp is run through a line out converter through my stock MACH 460
It almost sounds as if the subs are crosswired, but I konw they arent. The amp is still ok, it gets power, its grounded and the subs definitly move, just don't produce any bass. They also are producing large amounts of distortion at low levels of volume. At high levels of volume they produce no bass at all
I originally thought the Subs were blown, but after examining them it does not appear to be the case. Maybe my amp is fried (after a 3 hr drive on a really hot day) or maybe the line out converter is shot (three years old)
I took the box and amp comletely out, re-wired everything and I still have the same problem....so I am just not sure
any help would be appreciated, I just dont want to start randomly replacing things
first off,gently push down on the cone of each woofer evenly,if you hear a rubbing,you have blown voice coil.Next get a ohm meter and measure the resistance of each woofer and see if its near the specs(4 or 8 ohm).Just because the amp has power and the light is on doesnt mean the amp is good.I have seen and heard about JL amps blowing more then any other brand in a while.
Let me know what you find and we'll go from there.
alright thanks for your help, unfortunatley I do not have an ohm meter so I wil have to see what i can do about that
I pushed down on the woofers, no rubbing, they felt pretty normal actually. So i am assuming now our sights are set on the amp granted the ohm meter reads normal
now you say the subs are bridged are they ran in Parrelle or in series? parrelle mean the positive from sub #1 loops to the positive of sub #2 then to the amp. Series is when you bridge sub #1 + to sub #2- and run the amp leads to each respecting subs open slot(one will be hooked into + and other - )
sorry if you knew this already ...
I think the best way to run your subs might be to parallel everything.....all the voice coils running parallel to the output on the amp....
all + to + and all - to -
just go grab a cheap line converter from local shop and try it out....
