Help! Do I need CC plates?
  • Thread starter Thread starter JAZ 5.0
  • Start date Start date Apr 8, 2005
First Prev 2 of 2
Stang8URMPRT
1,100
Daytona Beach, FL
Apr 12, 2005
#21
  • Apr 12, 2005
  • #21
5LugFoxFanatic said:
Sure Stang8URIMPORT is right about not needing them for a regular car, but there is nowhere near enough adjustment in the stock plates for a car that has a decent drop. Another reason to go with a better C/C plate is to get a different bushing or bearing in the top to absorb bumps compared to the flimsly rubber one in the stock plates. Not a waste of money. Maybe if your car is stock yes. Lowered 1/1/2 inches. Nope.
Read the whole thread before you post. You can elongate the strut tower to allow more adjustment the "stock", and yes you can pull the camber in on a car that's dropped 1.5 inches. I've done it before without c/c plates.
NKau
1,346
Jefferson, WI
Apr 12, 2005
#22
  • Apr 12, 2005
  • #22
Stang8URMPRT said:
]You can elongate the strut tower to allow more adjustment the "stock", and yes you can pull the camber in on a car that's dropped 1.5 inches. I've done it before without c/c plates.
Problem is that I don't think elongating those strut holes is a very common practice at a lot of alignment shops (sounds like a good idea; never heard of it until now). I literally took my old '89 to two different alignment places that "aligned" it, and I had problems with wear on the insides of the front tires both times; ruined two sets of tires in a years time
That leaves you the option of finding a shop that can do the alignment RIGHT with stock plates, elongating the holes yourself before bringing the car in, or getting the c.c. plates. I chose c.c. plates because I didn't know of the strut tower fix before now, and because there are some advantages to aftermarket c.c. plates; most notably the spherical bearing on aftermarket v.s. the rubber strut mount in the stockers which actually deflects/binds in hard cornering (if you are at all into corner carving, this isn't a good characteristic) as opposed to just swiveling.
JAZ 5.0
178
Houston
Apr 12, 2005
#23
  • Apr 12, 2005
  • #23
Well a part of me just wants to get take it to Ford and align it, but I've been there twice and I feel that if they could elongate it, how come they didn't? The other part doesn't want to spend the $$$ on CC plates is the holes can be elongated. So what the heck do I do?
Stang8URMPRT
1,100
Daytona Beach, FL
Apr 12, 2005
#24
  • Apr 12, 2005
  • #24
Yeah man.. It's not common practice. Most shops won't do it cause it takes more time then telling you to go buy c/c plates and come back. Alignments can be painstaking and can take a while depending on how far things are out. I can adjust you drivers side... set it perfect, then go to the passanger side, move it .5 degree, and it just threw everything out on the drivers side. So you go take your time on these things.
JAZ 5.0: I wouldn't elongage the holes before going to the shop, because you need to know which way to elongate the holes and how far. I don't know why they didn't adjust it last time at Ford, but I fear you got someone that didn't want to deal with it lol. Go to your local speed shop... as when they have do their alignments and go there... and explain that you'd like the c/c adjusted by elongating the holes in the strut tower. If they haven't a clue what you're talking about... go elsewhere
JAZ 5.0
178
Houston
Apr 13, 2005
#25
  • Apr 13, 2005
  • #25
Ya, I won't be doing it myself. I guess I'll try to get it aligned before I shell out the doe for CC plates.
vristang
4,933
101
124
Seattle
Apr 13, 2005
#26
  • Apr 13, 2005
  • #26
Has anyone ever tried doing the alignment themselves? I think I remember seeing kits for the home mechanic. If anyone has how did it go?
Just a thought since so many of us have had problems with the so called Professionals.
Stang8URMPRT
1,100
Daytona Beach, FL
Apr 13, 2005
#27
  • Apr 13, 2005
  • #27
Wish yall lived around here.. I'd hook yall up with "Professional" alignments
JAZ 5.0
178
Houston
Apr 13, 2005
#28
  • Apr 13, 2005
  • #28
I've seen those kits, but I think the cost of them isn't low enough for me to justify the use of them. I won't be aligning it every month. I wish I could take it up to you Stang8
First Prev 2 of 2
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
