I have one of those Actron OBDII tools and saw these codes:
P1130 - Insufficent Switching 02 Bank 1 Sensor 1 Fuel trim at limit
P1131 - Insufficent Switching 02 Bank 1 Sensor 1 Sensor / Lean
I have done the following with no luck:
* Replaced both O2 sensors on the drivers side on the car.
* Replaced the MAF
* Replaced the spark plugs (a little worn .007 with just a little white)
I also know the following:
- Oil is changed regularly
- I run 91 octane regularly
- Gas cap is on tight
- Replaced fuel filter 10,000 miles ago
- PCV is good
- K&N air filter is good
- I cleaned out the idle control valve 10,000 miles ago and car idles fine
- Spark plug wires looked good and car gets 21 to 23 miles per gallon on the highway
Car is a 1998 Mustang GT and has 72,000 miles on it.
I would appreciate any suggestions or analysis.
Please let me know if you need any further information.
Thanks,
Alan
* Replaced the MAF
- PCV is good
Thanks,
Alan
