help!!! engine running hot...or is it?
Apsychotic
92
Hey all, I got a little problem going here, My temprature guage has never worked, but since we've been getting the hotter weather here in s/w pa. over the past week or two, The heat inside the interior of the car had become unbearable. To solve the problem, (or so I thought) I bypassed the heater core. Ever since I did this, the car still gets hot inside, and seems to be building more pressure in the radiator than normal, when I lift the release valve on the coolant cap, the overflow bottle starts gurgling like crazy. I'm not sure if this thing is actually running hot but not overheating or what? :flame:
Sounds like a good time to install a temp gauge to help better diagnose your problem. Were inside the car are you noticing the most heat? At your feet, coming from the trannie tunnel area?
