Help!!! Erratic revving..Motor is going nuts
  • Thread starter Thread starter Notched90
  • Start date Start date Mar 19, 2006
Notched90
64
  • Mar 19, 2006
Last night while doing my first burnout in a while, I seemed to have cracked a vacuum hose or damaged something that is causing my engine to go crazy. I searched the posts but didnt find anything that would help. Ever since last night my motor will:
Idle really low (550 rpms) then shoot up to 3200 rpms and hang there for about 20 seconds, then drop down and come very close to stalling. It goes nuts and revs itself up and down in between.
I checked everywhere for vacuum leaks, even using the old carb-cleaner method of spraying in potential vacuum leak areas and listening for a response in rpms. I checked every hose I could think of, and the only one that is actually cracked is the line coming off the EGR valve which was cracked prior to this.
Sound familiar?? I know this is very vague but I can't find the source and I can barely drive my car in the mean time....
slow93
406
  • Mar 19, 2006
have you checked the tps voltage to make sure it hasnt shot craps
HISSIN50
34
129
Mar 19, 2006
  • Mar 19, 2006
Do you know how much vac you are pulling? A stockish motor should pull nearly 20" hg.
What happens if you disconnect the IAC on a hot motor (for testing only, since this could lead to stalling depending upon how you set your idle)?
Good luck.
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
