When the Ford Racing instructions say adjust to achieve 1/4" of play, does that mean 1/4" from the pedal being pulled all the way up until it encounters resistance when you push it down? If so, this results in one very high clutch pedal!
90mustangGT said:I agree with JR but have to dissagree with Jrichker about preload. I don't know about actuall preload, but it should be close. I was taught that it should be adjusted to the point where the TOB stopps spinning (no contact) but I don't know because most hydrolic and self adjusting cable assemblies sit it so the TOB is in contact. There shouldn't be actuall pressure though, just contact.
The point is that you don't want to ride the TOB, because they will fail. I did a clutch job on a 99 Mustang Faleen V6 (I know, it was a V6 with a salleen bodykit, cheapo body kit as well) 60K miles, TOB nearly locked up, flywheel glazed, pressure plate with some glazing as well. I did the same thing with riced out civic, hydlolic assembly, but the kit drove around with his foot on the clutch all the time. Both jobs were about a $1000 or so, maby they learned thier lessons. I had to take them out and teach them how to drive a stick shift. It's amazing how many people don't know how to properly drive a manual transmisison. Just because you can make it work doesn't mean your doing it right.
As long as the cable and quadrant work together, it should be fine. For example, the SVO single hook has a huge, long throw, so the stock cable wont fit it - the adjustable Ford cable is required.criticman said:My question is, if I were to go to a non-adjustable cable, is the adjustability still good with the firewall adjuster and the multiple latch positions on the quadrant?
You kinda lost me. Where is the point of engagement in relation to the floorboard? Can you feel a little bit of 'soft' pedal travel before you start loading the PP fingers?Realmongo said:I finshed putting it in. I left it at 1/4" from the top mechanical stop but as I said the pedal is pretty high. I am worried about wearing the TOB too.
HISSIN50 said:You kinda lost me. Where is the point of engagement in relation to the floorboard? Can you feel a little bit of 'soft' pedal travel before you start loading the PP fingers?
Realmongo said:I called up Ford Racing, and this is what they told me to do:
1. have someone hold the clutch pedal all the way up against the mechanical stop.
2. Adjust all the play out of the cable.
3. Loosen the adjusting nut 1/4-1/2 Turn.
4. Tighten the jam nut.
