Help fuel pump question?
  • Thread starter Thread starter MY 85 GT
  • Start date Start date Mar 10, 2008
MY 85 GT
1,852
208
104
New Jersey
Mar 10, 2008
  • Mar 10, 2008
Ok today i went to replace my fuel with a carter performance street pump its a block pump anyways the stock one has three lines the new one has only 2 ...the new one doesnt have a return line im guessing thats the vent one....What can i do can i use the new pump and plug the return line what will happen any help would be great thanks.....
MY 85 GT
1,852
208
104
New Jersey
Mar 11, 2008
  • Mar 11, 2008
Ok i still didnt find out if it oks to disconnect the return line does anyone know if its ok?
MY 85 GT
1,852
208
104
New Jersey
Mar 11, 2008
  • Mar 11, 2008
BTTT i still dint find any info anyone......know what i can do? thanks
bt15
129
Oahu
Mar 11, 2008
  • Mar 11, 2008
Been There. Done That.
You have the right idea about how to handle your quandry. Simply hook up the in and out lines on your Carter (in fact that's the same pump I chose) and then block off the return line from the tank. Apparently, the third line had a few intended purposes. First, it was meant to keep the fuel and the pump cooler in the long run, by looping it between the pump and the tank. Second, it was intended to pressurize the tank to keep it in compliance with EPA rules. There was a third rationale for use that was to effectively act as a pressure relief / stabilizer for the system. That's what I read in the manual, at least.
All that said, I've been running my Carter pump in the manner described for 5 years now, with no adverse effects noticed. Go for it!
MY 85 GT
1,852
208
104
New Jersey
Mar 12, 2008
  • Mar 12, 2008
Thanks i did....I think the pump is rated for 6 psi and i have an edelbrock carb on there now...do you think that is too much pressure? should i regulate it...I still smell gas and the car is hard starting when warm actually it started bad this morning too when cold like it was flooded? and i have this weird stumble at all speeds in all gears if you just cruise if you get on it hard it isnt there thats because what every the problem is its getting coverded by stepping on it harder....
Fast63
717
  • Mar 12, 2008
pumps don't always put out what they are rated for. 6psi is the absolute max for an edelbrock. They recommend 5.5 and I recommend 5 for good measure. I say you should set up a regulator and a fuel pressure gauge. I had hard starting and fuel smell when warm when I was running too much pressure with my edelbrock, but no stumbling or anything. You can check your spark plugs to see if they are really black. If they are then you are consuming too much fuel, likely from the fuel pressure, and then your spark plugs are probably fouled.
MY 85 GT
1,852
208
104
New Jersey
Mar 13, 2008
  • Mar 13, 2008
Thanks for the info I have an carter fuel pump 6-6.5 psi at 120 gph block pump...and i have an edelbrock 1406 carb i pulled the plugs yesterday and there pure white...i guess its running a little lean...plus the timing is set at 0 degress its at top dead center so im guessing that not good either? so i bought an 1806 edelbrock 650 cfm thunder series carb i hope this helps..... with the lean condition....i heard the 1406 runs very lean.....probably not a good choice for the 5.0
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
