help!!!!!!!!!!!!help!!!!!!!!!!help!!!!!!!!!!!!!!
  • Thread starter Thread starter yourtransamsuck
  • Start date Start date Mar 5, 2004
Y
yourtransamsuck
17
Eglin AFB FL
Mar 5, 2004
  • Mar 5, 2004
i just rebuilt the engine in my 92 5.0, i'am leaking coolant at the firewall below the heater hoses. its draining from a hole from the firewall. i dont know if its a drain or what.
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Mar 5, 2004
  • Mar 5, 2004
heater core man! Good luck with that... But check your hose fittings
Also in the future maybe a better title would get faster response
Y
yourtransamsuck
17
Eglin AFB FL
Mar 5, 2004
  • Mar 5, 2004
are you sure its the heater core the leak is on the out side of the car
Y
yourtransamsuck
17
Eglin AFB FL
Mar 5, 2004
  • Mar 5, 2004
OK thanks for your great wisdom BOSS 351 that really helps
Boss 351
Jul 13, 2003
2,433
23
48
Canada
Mar 5, 2004
  • Mar 5, 2004
hey just trying to help.. no need for attitude.
ALMOST STOCK
1,250
41
88
CA.
Mar 5, 2004
  • Mar 5, 2004
I just had to replace my heater core because of the same reason you’re talking about; leaking antifreeze through the plastic tube that exits the firewall under the heater hoses. In my case while removing the rubber heater hoses I cracked the soldier joint on the heater core which caused the leak in mine
BlackGT89
774
Huntsville, AL
Mar 5, 2004
  • Mar 5, 2004
Looks like your in Fla - bypass it for the summer or until ?
P
PRO50SC
1,012
Olney, Maryland
Mar 5, 2004
  • Mar 5, 2004
Yes, it is a drain, for your a/c condensation. The evaporator and the heater core are contained in the same housing. When the core leaks it will run out of that drain as well as probably on your carpet. Sucks to be you right about now Major PITA job. Good luck.
L
Engine New guy heater hose question. 85 gt 4bbl.
  • linemech31
  • Jan 17, 2026
Fox 5.0 Mustang Tech Jan 20, 2026
General karthief
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Engine Bleeding air in the heater core
  • keel
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 23, 2026
limp
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
