This is for 2000 Mustang, It is easy
Every back yard mechanic has an old pair of windshield wiper blades, take the spring steal strip off one side of the old wiper blade! do not modify, It will bend and go right in with no modification.
1. push the seat cover down from the plastic grommet at the base of the post of the head rest
2, on the front , motor side of the seat, there is a groove in the headrest supporting bar.(post)
3. insert the spring steel under the grommet(below) in the slot, push down until it stops.about 3 or 4 inches.
4. gently wiggle the head rest and gently push and the spring will slip past.
5. proceed down to about 8" and you will feel resistance again, wiggle the head rest again, when you go past,
your almost done!!
6. leave the spring in place and/
7. the head rest will lift out!!
read this twice, take it
off in 40 seconds, no grief.
Cheers!!
Dave
http://www.stangnet.com/mustang-forums/images/smilies/rollinglaugh.gif
