OK I took apart the T-5 because the speedo did not work (Could not feel the gear in tranny)The yellow gear is just spinning on the output shaft,I get a retainer clip from a tranny shop put the clip on ,put yellow gear on,slide rubber collar on.Speedo still does not work! Yes I put a drill on the cable the speedo works.Am I missing something else ? is there a certain way the gear goes on the output shaft? Any tranny guys in here I coul use some help!
