Help identifying this engine
  • Thread starter Thread starter TireSmoknWindsr
  • Start date Start date Apr 4, 2004
TireSmoknWindsr
1,630
Half past whup'n some import's ass
Apr 4, 2004
  • Apr 4, 2004
This was the only numbers I could access from the intake and front of the block. on the intake is a big S and G and between them is C6AE 9425 the valve covers state its a 1970 428ci and I still want to be sure its not just a fake. Block has 352 8 cast into it which I couldnt remember if my 390 had an 8 too or if the different FEs had different numbers below the 352 stamp.
68GEETEE
5 Year Member
Nov 21, 2003
481
Texas, USA
Apr 4, 2004
  • Apr 4, 2004
Its a 1966 Casting number, but they keep the same number if no changes are made, so I am not sure.
http://www.ford-y-block.com/fordpartnumbers.htm
http://www.wantabe.com/hdrace/dfrdpt.htm
http://www.mustangsandmore.com/ubb/FordTechData.html
Hope one of these can help.
9
96 DOHC Cobra
542
Cerritos, CA
Apr 4, 2004
  • Apr 4, 2004
The intake is a common part, NOT CJ. Does it have a holley carb on it? Look between the middle two spark plugs on the heads. The CJ heads will have "C8OE 6090-N" cast into there. The rest, you'll need to pull the pan to confirm. The crank will have '1U" or "1UB" or "1UA" cast into it. The rods won't have the common 9/16" bolts. The CJ rods use a very uncommon 19/32" nut.
D
D.Hearne
11,730
south louisiana
Apr 5, 2004
  • Apr 5, 2004
easiest way to ID a 428 ( or 410 ) is to look for the counterweight on the flywheel or flexplate. Could be a std 428 if not a 360/390/410.
LMan
1,246
Mom's basement
Apr 5, 2004
  • Apr 5, 2004
I *think* 1969 was the last year for the 428. I will shamefully confess failure if I am incorrect.
P
Pbford
21
South-Central TN
Apr 5, 2004
  • Apr 5, 2004
1970 was the last year of the 428 in the Mustang.
TireSmoknWindsr
1,630
Apr 5, 2004
  • Apr 5, 2004
That would be 1970 Mustang wise. Hence the powerplant of the 70 R code cars and the G.T.500s. Not sure the last year of the 428 itself though.
LMan
1,246
Mom's basement
Apr 5, 2004
  • Apr 5, 2004
I have sinned, O Lord...... :worship:
Edbert
3,548
32
109
Austin TX
Apr 5, 2004
  • Apr 5, 2004
...and for your pennance you will have to give the thumbs up to the next 6 Chevelles you see and say 3 hail-camaros!
9
96 DOHC Cobra
542
Cerritos, CA
Apr 5, 2004
#10
  • Apr 5, 2004
  • #10
In 1970 the 428 was also used in police interceptors and in the Mustang's cousin, the Cougar. I think these were the only applications for this motor (428 both CJ and non-CJ) that year, and it was the last year.
D
D.Hearne
11,730
south louisiana
Apr 5, 2004
#11
  • Apr 5, 2004
  • #11
The 428 was available later than 1970 in industrial and agricultural applications.
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
R
Need help identifying engine
  • rustang67
  • Mar 4, 2025
  • SVT Tech Forum
SVT Tech Forum Mar 27, 2025
Mustang5L5
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Yesterday at 2:12 PM
mattcrp1
M
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
