HELP: idle/ stalling problems
  • Thread starter Thread starter russ1979
  • Start date Start date Sep 26, 2011
russ1979
152
albuquerque, new mexico
Sep 26, 2011
  • Sep 26, 2011
for some time now the motor has been having idle problem when cold but after the car warms up it's fine. well yesterday it got worse. i have to keep the eng alive by reving at lights and full throttle when on the gas. there is no check eng light and the car runs but i will prob. get arrested if i drive it like this to much
I'm thinking it may be the t.p.s. or the i.a.c. but i don't want to just swap parts with no real idea of what it is.
any body have any ideas?
i used the search but go nothing.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 26, 2011
  • Sep 26, 2011
See the "Surging Idle Checklist for help with all your idle/stall problems.
The quick and easy way to dump the codes is in there too, and all you need to do it is a paper clip! The first two posts contain all the fixes & updates. At last count there were 24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
russ1979
152
Sep 26, 2011
  • Sep 26, 2011
I'll check it out.
there is no check eng light.
i cleaned the i.a.c. really well with carb cleaner and q tips.
it helped a lot but did not completely fix the problem
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 26, 2011
  • Sep 26, 2011
russ1979 said:
I'll check it out.
Codes may be present even if the check engine light isn't on. Always check them, most of us can afford a paper clip to do it with...
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
2001 SVT Cobra slow return to idle speed
  • phil2001svt
  • Oct 21, 2026
  • SVT Tech Forum
SVT Tech Forum Nov 2, 2026
phil2001svt
