  • SN95 4.6L Mustang Tech
HELP installing Pro-Kit
  • Thread starter Thread starter yamie700
  • Start date Start date Apr 10, 2004
Y
yamie700
67
MN
Apr 10, 2004
  • Apr 10, 2004
Trying to install Eibach pro kit in front. Have old springs out but can not get the new ones in. The part # on the springs themselves are 3510.301 (front) and 3510.302 (rear). The part # on the box is 3510.140. My new springs are about 3/4" shorter than the stock ones. Is this right? I can not get the new springs back into the "cups" where they are supposed to go. I do not have a spring compressor and I don't think I will be able to get one. Stores are closed now and it is easter sunday tomorrow. I need to go back up to school from my parents house sunday night so I need HELP. Any suggestions and are the part #'s right. These new springs seem too close to the stock length.
P
PEWTERPONY
829
NE Atlanta
Apr 10, 2004
  • Apr 10, 2004
Make sure your have the right springs on the right end......front ones are huge diameter (beefier) back ones are less beefy. They should fit right into the isolators and into the seats on the frame. Don't freak over the length of the springs either. Keep in mind that the ones you took off have way beyond settled.....the eibachs have not even. When you settle, you'll like the drop. Its not extreme and great for every day driving. You'll drop around 1.5+ inches
M
millatime
370
Palm Harbor, FL
Apr 10, 2004
  • Apr 10, 2004
you have to work the strut around the wheel well so you can pull the top portion out of the wheel well. They you can use it for the little leverage you will need to push the a arm down a little...its not too hard to do
by the way...this might sound stupid but you need to compress the shock as well.
nyuk98gt
1,427
Chesterfield, MO
Apr 11, 2004
  • Apr 11, 2004
yamie700:
If you have not done so, please check out Spreadman's excellent spring install article (Tech Articles on this board). The shorter springs should go in easier than the stockers came out. On the fronts, it is helpful to pop the outer tie-rod ends (hammer them out or get a little press from AutoZone (they should be open today/Sunday)).
As for the part numbers, maybe the number on the box is for the entire kit (4 springs)?
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
N
Fox Street Suspension Build Advice
  • NYFox
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
