- Jun 17, 2015
- 43
- 27
- 28
Im working out a couple of small issues, and a new one cropped up.
my instrament lights arent working.. i replaced my heater core.. reinstalled everything and replaced a few bulbs and everything was working well. also installed a new stereo. Now all the sudden they arent working.. not just my dash but also the heater controlls etc.. if i adjust my dimmer nothing happens, but i can adjust the dimmer all the way up and the dome light goes on as it should.. i checked my fuse, looks fine. im gonna check the "lumination" wire on the stereo as i found other threads where that was the problem, but for them it was popping fuses as well, and i dont think i even wired it up. i guess ill start checking wires.. but shy of that im thinking its gotta be the dimmer switch ? any other thoughts?
Also my wipers arent working. i havent tested the relay/motor/ or fuse itself yet, my question is , how do you test the "fuse" as it doesnt look like a normal fuse, looks more like a relay.... if its got continuety its good?
thanks gents..
thanks gents..
