Help!! MAF troubleshooting
  • Thread starter Thread starter Blue347stang
  • Start date Start date Sep 6, 2004
Blue347stang
81
San Antonio,Texas
Sep 6, 2004
  • Sep 6, 2004
I'm having trouble with my car running lean. I'm thinking it's the MAF from Pro-M. I checked out their website and on there it said to check the voltage on the A-D pins.This is what it should read: Pin A:12v, Pin B:Ground Negative, Pin C:Internal Ground 3.5-4v ,Pin D:Output +. My readings are: A:14 volts, B: .11 volts, C: .11 volts, D: .7-.9 volts. I recently hid my wires through the outside of the fender and moved my battery to the trunk. Now I read that when moving the battery to the trunk you must run your negative to the original position which is on the timing chain cover/Block. Then you must run a smaller gauge wire to the floor of the trunk. I haven't done this, I have my negative bolted down to the chassis in the back of the car. I then have another cable bolted on the same side of the chassis but up in front connecting to the block. Could this be my problem?
Blue347stang
81
San Antonio,Texas
Sep 6, 2004
  • Sep 6, 2004
ttt
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 7, 2004
  • Sep 7, 2004
Battery in rear:
One 1 gauge or better from battery negative post to engine block.
One 4 gauge or better from battery negative post to chassis ground point near battery. You can use any of the sheetmetal flooring, just be sure to sand it clean & shiny where you bolt the cable.
One 4 gauge or better from the engine block to the chassis ground point where the battery used to live. Best results are when you use the same ground point as the ground cable coming from the battery.
One 1 gauge or better from the battery positive post the the starter solenoid.
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
