Here's the scoop.
I want to start a long term project to build up a stout short block to better compliment my top end and of course make more power reliably. This is a project I would like to build as I slowly acquire parts. I would like to be in the 300 wheel horsepower range N/A (Which I don't think is unreasonable).
My car is 99% street duty, and cruising around town. I found out that in fact I do a lot of highway driving so higher gears are a must (no more than 3.25:1), as well as I need it to not want to stall at stoplights and be able to operate the power steering and power brakes in parking lots.
I would like to reuse as much as the top end parts as I can (Heads, intake, carb, roller rockers). And I would like to keep the fuel supplied with a mechanical fuel pump.
My current set up is:
302 block 289, 0.030" over
Stock crank, rods
Cast 0.030" pistons (Brand unknown)
Afr 165's, 61cc combustion chambers
Comp XE262H Cam
Crane Blazer 1.6 Roller Rockers
Speed Demon 650 Vac Sec Carb
Edelbrock Performer RPM Mechanical Fuel Pump
So what I need your opinion on are the following:
Block:
I would like to go to a roller cam, but don't like the idea of retrofitting a non-roller block. Should a stock roller block do fine (reliably) for my power goals?
Crank:
I would definately like to go to 331 cubes, so a stroker crank is in the cards. I know a lot of people would say that the AFR 165's are small for a 331, and that the 185's are a better choice but I don't care about absolute peak horsepower potential. I think the 165's should still make more power on a 331 than a 289. What brands would be a good choice?
Rods:
Type? Brand?
Pistons:
Type (I don't mind paying for Forged if it's worth it, I wouldn't mind the option of putting a small shot of nitrous on the motor down the line)? Brand?
Bearings:
Brand?
Cam:
Any recommendations?
Stud Girdle?
Helpful or waste of money for me
Of course all fasteners would be ARP.
Am I missing anything?
Stock crank, rods
Comp XE262H Cam
Block:
Crank:
Rods:
Type? Brand?
Pistons:
Bearings:
Brand?
Cam:
Stud Girdle?
I mean sure I have a big strength potential, but I can't imagine I'd make enough power to need to have that much strength. I think it would also be out of my price range.
