  • Mustang Sound & Shine All
Help me build a sound system for a foxbody vert
  • Thread starter Thread starter silverlx50
  • Start date Start date Apr 3, 2021
First Prev 2 of 2
Wayne Waldrep
Before I post a pic, do you have one of yours?
20+ Year Stangneter
Apr 14, 2003
1,338
659
143
Cuba, AL
Jul 25, 2023
#21
  • Jul 25, 2023
  • #21
Just my opinion but decent sound (especially asking for more bass) equals aftermarket amp. It's just not going to be very good without one. Again, my thoughts.
R
Ricco Suave
Vancouver
Nov 24, 2023
#22
  • Nov 24, 2023
  • #22
^^Agreed^^
I am only just starting mine but I've always had a system in my car's.
Had a Cobalt SS/SC that was all Digital Designs that hit 142 when back when but that was many moons ago
I have a leak in my drivers side back window so since I had to pull the whole interior out I figured now is good time to Dynamat.
I haven't made up my mind on a HU yet but I have a set of Focal 6.5's for the front which I'm making fiberglass pods for.
Then I'm going with 2 8" Sundown XV.48's
I'm going to build the box in the area where the bars are that hold the trunk up (I'll have to switch to hydraulic) and then go with 2 round ports and extend them up into the cabin through the existing holes for the 6x8's in the deck lid. Box will be tuned to 32-33 hz
I have a CAB 22 to run the subs and an CAB 44.4 to run the front end.
As for the HU... IDK its been a while since I've had a car that actually allowed me to replace the HU so Ill have to shop around
Something Double din and has to have 5 v preouts.
I've also ordered a 240 amp Alt from Mechman and debated going Lithium for a battery but I'll probably just go with a Northstar AGM or sorry Odyssey (Northstars Canadian counterpart) because you can't get NorthStar up here in the great white north
I probably wont even be able to hear it over the sound of the engine though but I've got all winter to put it in
Gunmonkey
54
28
38
South Florida
Feb 18, 2024
#23
  • Feb 18, 2024
  • #23
ChaseRoads said:
Hey, sorry to bump an older post. I hat would you suggest to use when mounting speakers in different sized holes like you did with the rear speakers? I plan to do something similar as well as run tweeters in my dash but unsure what to use to mount the speaker
Note sure if you’re still looking for info, but I just installed a whole system in mine, and replaced the 3.5s in the dash with component tweeters. I made a bridge using a 1/4” piece of plexiglass, drilled a hole in the middle for the tweeter, and screwed the bridge into the dash hole using the 2 existing screw locations.
First Prev 2 of 2
Radio, Speaker Upgrades
  • TripleYellow
  • Apr 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 24, 2026
TripleYellow
Stereo snakes nest; what am I missing?
  • Scott_S
  • Aug 29, 2025
Mustang Sound & Shine All Sep 24, 2025
Scott_S
G
Electrical Getting good ground in 1991 Fox Vert for amps - getting popping noise when I turn on the lights?
  • gvanginkel403
  • Apr 11, 2026
Fox 5.0 Mustang Tech Jul 21, 2026
gvanginkel403
G
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
P
Interior and Upholstery Door Speakers- found suggestion to go component, not coaxial
  • pindude80
  • Apr 21, 2025
Fox 5.0 Mustang Tech Apr 28, 2025
Mindseye007
