help me fuel pressure
  • Thread starter Thread starter anthonylanthrip
  • Start date Start date Aug 25, 2006
A
anthonylanthrip
11
sylacauga,al
Aug 25, 2006
  • Aug 25, 2006
i purchased a 95 gt mustang and it has a few problems, first it has a e 303 cam , tremec ,alum driveshaft,gt 40 heads off a explorer ,bbk air intake,stock upper and lower intake and stock mass air flow, and injectors. the car is strong but is running extremely rich i mean it will burn your eyes to be behind it.i hooked a ob 2 scanner to the computer and it wont read the computer says it has a data link error. i dont know if it because the blub has been pulled out of the instrument panel. also it idles rough and the car idles high at red lights until it fully stops than it idles down and if you step on the gas the rpms stay high for a minute and then finally drops . i know i am asking alot but in sylacauga al nobody knows how to fix problems just bypass them. if anyone has this problems please help it would mean somemuch to me.
bill302
2,131
alabama,gadsden
Aug 25, 2006
  • Aug 25, 2006
wrong scanner ours is obd1 the test port is located under the hood on passenger side between the back of the wheel well and fire wall....don't ask me why the obd 2 test port is under the dash in our cars but it does'nt work....autozone will retrieve the codes for free...also click on link below for some info on pulling codes yourself...pull codes and repost results...
http://www.muscularmustangs.com/test1.php
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 25, 2006
  • Aug 25, 2006
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
Wal-Mart may now have the LCD display scanner for less than $35
Post the codes & I will post the meanings of the results & what to do to fix them.
HISSIN50
34
129
Aug 25, 2006
  • Aug 25, 2006
Welcome!
The V6 1994-95 stangs are OBD-II, hence the data port under the dash. As said, it's useless on a GT(S)/Cobra.
Bill and JR are right-on. Get those codes (3 digits for you) and go from there.
Good luck.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Aug 25, 2006
  • Aug 25, 2006
Um i had a 95 gt also, those things really really really really hate cams intakes! Mine idoled like **** to when i had the H/C/I on there my buddy had a chip installed cause he couldnt get his to idol at all so he had to get a chip burnt! If i remember right tho i had 35-40 PSI of fuel pressure with the vac line off. peace
john
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Holley High-ram tuning settings
  • spencergt66
  • Apr 1, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jun 19, 2026
spencergt66
J
Engine Running like crap :(
  • justadude07
  • Sep 27, 2025
Fox 5.0 Mustang Tech Oct 19, 2025
DadLife0724
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
