help me plan my eng build
  • Thread starter Thread starter russ1979
  • Start date Start date Nov 28, 2007
russ1979
152
albuquerque, new mexico
Nov 28, 2007
  • Nov 28, 2007
i'm trying to pick what parts i whant for my project and what path to take to reach my goals.
THE CAR: a 88 lx 5.0. it will have a tko 500, 5-speed. the eng is out of the car right now and i have sold the gt-40 heads and rpm2 intake to pay for the trans. that was missing when i bought the car. the short block has 150k miles on it and it prob needs a re-build
THE GOAL: a mid 12 sec. street car (street tires,and pump gas) that will act like a stock mustang till i punch the gas. i need it to pass the sniffer (e-test). however it will not be a daily driver just a fun weekend toy but i don't whant to have to be always be working on it.
THE POSSIBILLITYS:
A: buying a stock intake and heads as cheap as i can find them, taking the eng back to stock then throwing a turbo on it with a tuff as nails 306 short block. my major problem with this is i realy don't thant to lose the priceless sound of a 5.0 with a h-pipe and flowsmasters.
B:a 347 with good flowing h/c/i keeping the comp. down to add a supercharger later if i need it and or whant it later on.
C: keep the eng near stock and supercharge it
D: 306 with h/c/i
E: other
so what do you guys think? what would you pick? cash is a issue this is not on a un limited budget but i will spend cash where i need it. oh and no juice
been there done that.
87foxstang
Cromwell, CT
Nov 28, 2007
  • Nov 28, 2007
I would definitely go with the H/C/I 347
russ1979
152
Nov 28, 2007
  • Nov 28, 2007
why
D
Daggar
3,902
  • Nov 28, 2007
There are at least a thousand different ways to reach those goals. Due to that, this thread is an opinion poll and not a technical issue.
--moved to talk section--
russ1979
152
Nov 28, 2007
  • Nov 28, 2007
fair enuff
D
Daggar
3,902
  • Nov 28, 2007
I posted this in another thread but thought you might wish to review they "why".
Daggar said:
shopping thread
--moved to talk--
Friendly Note:
I've been seeing a lot of these kinds of threads lately and just wanted to remind folks about what the difference is between a Talk thread and Tech thread.
A Talk thread includes all of those things that ask for an opinion, are created for the purpose of shopping, or are just not technical in nature.
A tech thread is just that. A technical question or set of instructions for a fix, repair, modification, or proceedure.
So a talk thread might start out like, "What set of heads/blower/underglow kit/headlights etc. should I get for my 19xx Fox?" vs. a technical thread that would start out like, "How do I install this set of heads/blower/underglow kit/ headlights etc. on my 19xx Fox?" -- or -- "What modifications do I need to make to my car in order to install this set of heads/blower/underglow kit/headlights etc. on my 19xx Fox?"
See the difference?
Sorry to interrupt your thread.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 28, 2007
  • Nov 28, 2007
Very standard goals there and I like them.
russ1979 said:
THE POSSIBILLITYS:
A turbo sounds very nice on a 5.0L. The 306 will only be as tough as the block you have it in. I am assuming stock. They are good to around 500 bhp and reliability and piece of mind start to fade away. A turbo is likely to be a bit more expensive than a standard supercharger kit, unless you can "engineer" a kit yourself.
Sounds like a great idea, but again the block is going to be your weak point. I would NOT add a blower to the mix of a decent flowing 347. So I would give a suggestion for a N/A 347 that can easily put you at high 11's with some drag radials and good driving.
- 347 (5.315" rod/1.175" piston)
- AFR 185's
- Holley Systemax
- 30-36 lb injectors
- 70mm Accufab throttle body
- 80mm Pro-M MAF
- 1 3/4" headers with a decent collector length
- FTI custom cam (let him know you want to pass the "sniffer")
Easy "mid-12's" and more with that combination and it will be reliable.
This is not a bad option but mid 12's will be a little harder to come-by without increasing the boost, to 10+ psi. Then you are working with a factory bottomend and stock headgaskets/bolts. You will want a good set of headgaskets, head studs, and a solid tune from a reputable shop.
russ1979 said:
D: 306 with h/c/i
This combination is done by many and can be done as well with some drag radials. In fact, I did it for my car (but emissions was not a concern). Here is what I would do personally.
- Bored .030" (306 cubic inch)
- AFR 165's or Trickflow Street or Track Heats
- Edelbrock Performer (lower ported to match)
- 80mm MAF from Pro-M
- 1 5/8" longtube headers, offroad H, and your choice of muffler.
- FTI custom cam (tell him about emissions concerns)
russ1979 said:
E: other
I think A-D options are some good ones to start with...
I do not like nitrous either myself. Just an opinion of mine.
How much are you looking at spending, because much of the time, it cost 2x more than you would realize.
russ1979
152
Nov 28, 2007
  • Nov 28, 2007
this is going to be kinda a pay as i go kinda deal. i have a daily driver so this project does not have to be put togher fast.
but the cheaper it is thow the faster i get to have fun in it.
NKau
1,346
Jefferson, WI
Nov 29, 2007
  • Nov 29, 2007
I'd think the 347 would be the easiest
russ1979
152
Nov 29, 2007
#10
  • Nov 29, 2007
  • #10
anybody elese?
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
