• Community Forums
  • Regional Forums and Event Information
help me please!!!!!
  • Thread starter Thread starter whtsaleenrep
  • Start date Start date Aug 11, 2005
  • 3
1 of 3 Next Last
W
whtsaleenrep
63
kent washington
Aug 11, 2005
  • Aug 11, 2005
ok heres the problem. this is two weeks ago
my car was running perfectly except for a majore oil leake from the rear of the new intake i put on , so i parked it for the night and was gonna go get a new set of gaskets to redo the lower intake so the next day i start the car and take off and the car is running like ****.
it started to sputter like it was clogged inj, so i put some inj cleaner , didnt work.
so i checked the spark plug wires found my #1 cyl wire was bad so i replaced all wires, still didnt work
thought that maybe i had a crack in the cap so i replaced it, did nothing
took my distributor in and replaced the unit on it , nothing. still runs like **** ,i have power but i can tell im not at 100% it runs really chopy. i
im getting fuel presure , from what i can tell i dont have a vac leak but possible. the only things that i can think of that are left to change is plugs , wich i just change about a month ago , my computor or I DONT FU%$#@* KNOW. im so pised can anyone help. i live in kent if some is willing to come check it out. or what ever thanks garry
Black 93 Fox
1,995
Vancouver,Washington
Aug 11, 2005
  • Aug 11, 2005
I would start by fixing the intake first.
W
whtsaleenrep
63
kent washington
Aug 11, 2005
  • Aug 11, 2005
i already did that
Cobra_Dusten
246
Marysville, Wa
Aug 11, 2005
  • Aug 11, 2005
fix the problem you know you have, before you start throwing money at ghost problems, intake leaks will cause all sorts of cool problems
W
whtsaleenrep
63
kent washington
Aug 11, 2005
  • Aug 11, 2005
well it doesnt leak at the lower intake any more , now im not 100% but about 80% sure that theres no vac leaks anywere else.
Cobra_Dusten
246
Marysville, Wa
Aug 12, 2005
  • Aug 12, 2005
i posted that while you wree posting you fixed the leak
W
whtsaleenrep
63
kent washington
Aug 12, 2005
  • Aug 12, 2005
ya thats what i thought , so can u think of anything else i could bee missing?
ddonaca351
2,055
Camas Washington
Aug 12, 2005
  • Aug 12, 2005
Well its kinda hard to help without a little more detailed info, but we'll give it a shot...
Be sure all intake leaks are taken care of, unmetered air can reak havok on the computer trying to run things...
Is it possible the distributor hold down was loose and the timing is now hosed?
Could someone have put something in the gas tank?
Are all the plugs tight?
Are the wires routed correctly? (plugs that is)
Is the oil level or coolant level changing?
Did you get gas somewhere other than normal?
Did you knock a wire loose on the maf or one of the injectors?
Start simple... it is probably something really easy.
DD
W
whtsaleenrep
63
kent washington
Aug 12, 2005
  • Aug 12, 2005
i always get gas at shell, all plugs are tight, new wires are routed good,oil and coolent are good, inj are new with difrant maf
(pro m) my gas tank is a lock kind and it was running perfectly the night befor what do you mean when you say that the timming is hosed, do u mean off or ****ed and i need some major work done like timming chain ect. thanks garry
W
whtsaleenrep
63
kent washington
Aug 12, 2005
#10
  • Aug 12, 2005
  • #10
the only thing that you mentioned that really i m not sure of is the vac leaks. all lines are connected so if it is a vac leak i would need a tester and i dont have one an really dont have the money to get it. hell i dont really have the money now but i just got laid of today and i need to go out and find another job.
W
whtsaleenrep
63
kent washington
Aug 12, 2005
#11
  • Aug 12, 2005
  • #11
if anyone is interested here is my # you can call any time thanks garry 253 740 7462
hungrymonkey
White by Birth, Trash By Choice
12
108
Oregon.
Aug 12, 2005
#12
  • Aug 12, 2005
  • #12
did you pull the dizzy to put the intake back on?
you might be a couple teeth off.
Its kind of hard to work on cars through the internet.
W
whtsaleenrep
63
kent washington
Aug 12, 2005
#13
  • Aug 12, 2005
  • #13
ya i know tell me about it, i really wish i could spend the money and get it done by a shop but i dont and im not realy shure how far i can make it before she breaks down.
the dizzy? im assuming the distributor, and yes but my timming is good. i can drive the car but it runs like **** and once she gets warmer she begins to die every so often. it just dont make sense how i parked for the night and the very next day it runs like ****.
stock50LX
Curmudgeon
1,858
University Place, WA
Aug 12, 2005
#14
  • Aug 12, 2005
  • #14
Garry, what year is your car and what intake did you put on? I might have some gaskets for you (I remember a '91 and TFS intake but I am not positive).
Check to see that your ground wires, the ones that
connect to the intake or the back of the heads, are still bolted down.
If you removed the intake, you disconnected the MAS and all the vacuum lines. Check to be certain that the really thick line to the PCV valve is tightly connected and properly in the lower intake.
If I were you, I'd remove the intake and reinstall the gaskets as you planned to do. Check every connection as you reassemble. Did you use the proper tightening sequence on the lower intake? Did you lose any nuts or bolts in the process of changing intakes?
Did you change the TB and EGR spacer too? If you did, or if you reset your idle, I would focus some attention on your TPS. Be certain it's not loose.
How close are you to the track? PM me your address. I will try to come-by today.
84Gt350
298
Kirkland, WA
Aug 12, 2005
#15
  • Aug 12, 2005
  • #15
Sounds like the timing is off, did you pull the spout connector when setting the timing?
Dan
stock50LX
Curmudgeon
1,858
Aug 12, 2005
#16
  • Aug 12, 2005
  • #16
whtsaleenrep said:
i already did that
I just reviewed all the posts. I need a clarification: Did you reinstalled the lower intake to correct the leak you had in the back? -and you had the same problem you had before the reinstallation? Is that correct?
W
whtsaleenrep
63
kent washington
Aug 12, 2005
#17
  • Aug 12, 2005
  • #17
there wasnt any problems with the car besides an oil leak from the lower intake, and the car ran fine just had a big leak. so that night i parked it and the next morning i went to go the the store to pick up my gaskets, thats when it went to **** . there is no leak anymore and the problem started before i redid the lower.t5hats why it doesnt make sense because all it did was sit overnight and the next morning it ran like crap.
hungrymonkey
12
108
Oregon.
Aug 12, 2005
#18
  • Aug 12, 2005
  • #18
so the problem started before you did any work on it?
maybe one of the egr lines cracked when you were working on the car. It will cause power loss at wierd moments.
W
whtsaleenrep
63
kent washington
Aug 12, 2005
#19
  • Aug 12, 2005
  • #19
pretty much . i put the new intake on and it ran fine but began to leak a few weeks later so i parked it on fri and got up to leave sat , thats wen it started its problem. i have checked all my lines and havnt found anything.
W
whtsaleenrep
63
kent washington
Aug 12, 2005
#20
  • Aug 12, 2005
  • #20
i just got done checking all my plugs and found that they were alittle wet so i cleand each one of with some alchahol and put them back but still runs ****ty.
  • 3
1 of 3 Next Last
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Monday at 3:10 PM
Creomod
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
  • Community Forums
