Help me price a 5 lug conversion
keith1991 said:
If you want to run 9" wide rims do not order 94 and up axles. They are 3/4" longer than foxbody axles. You'll have to order foxbody length 5-lug axles.
Ok, so I could still buy the axles from the ranger and aerostar? That is if I want 9" rims. The writeup above has 8" Bullitt. I'll have to research later.
I have done two conversions My first one i didnt shop around I just bought the stuff off ebay and payed a little bit more.
90GT I spent:
$289-calipers, rotors, spindles from a 95GT
$130-5-lug axles
89LX I spent:
$220-shipped calipers, rotors, spindles, new hoses off a 94GT
$110-5-lug axles
Both I bought ranger 9 inch drums for 32.99 a peice.
Axle lube-10$
400-500$ per conversion roughly give or take a few odds and ends.
edit*-corral.net is your friend I bought the stuff from another member be sure to check the classified feedback forums and do a little research you will find what you need.
90GT I spent:
$130-5-lug axles
89LX I spent:
$110-5-lug axles
Axle lube-10$
This list seems to be alot simplier than the list given through the link above. Why replace the brake booster or go to the 3-2 conversion kit? Is this only the case if a person is replacing the back brakes with rotors?
I peiced my kit together. It's a j/y 2300K kit basically.
'95 Spindles = $100
'95 Cobra rotors = used $25 + $10 to have turned
'98 Cobra calipers = $150 + $40 for rebuild kit
Cobra dust shields = $15
99+ Cobra brake hoses = $25
Pass side brake hose adpater = $3
Pads = $50
Front total = $418
Rear SN95 axles = free from friend
2300M Cobra disk kit = $180
GT rear calipers, brackets and anti-moans = $100
Sold GT brackets and anti-moans = +$75
Rear brake hoses = $40
Rear brake line adapters = $5
Pads = $30
Rear = $280
Booster/MC
'95 v6 booster/MC = $25 from ebay
FMS prop valve plug = $9
3-2 conversion kit = $25
adjust. prop valve = $40
fluid = $20
total = $119
Total Cost = $817 (roughly)
I spread this out over a few years of gathering parts.
I don't have an e-brake yet. should be nothing more than a pair of cables and a weld to my stock handle.
