Help me select springs
  • Thread starter Thread starter Jack's95gt
  • Start date Start date May 17, 2010
J
Jack's95gt
443
Huntingdon Valley, PA
May 17, 2010
  • May 17, 2010
My 93lx which began life has a 2.3, 4 cylinder. I still have the original rear springs and the back is low with such things as a cage, battery box., sump tank and larrg fuel pump. I want it up about 1 1/2" - 2 ". What springs can I get to give it some lift? There's penty of take off springs available on ebay from late model SN197's being lowered. Would these work?
stang&2Birds
2,091
New England. :-) CT/MA
May 18, 2010
  • May 18, 2010
Hi.
Unfortunately, you're not going to get that type of addition height with just springs. Putting poly isolators will add ~1/4" to 1/2". It all depends how worn your isolators are now. Rear springs from 00-02 GT DOHC will raise the rear of a Fox GT by roughly 1/4" to 1/2". Again, there are a number of factors.
So, you may be able to raise the rear up by 1/2" to ~3/4" with 00-02 DOHC springs and poly isolators.
After that, you're looking at a few different options to raise the rear. It all depends on how much higher. I think that ?MM? sells weld-in rear spring perches to raise the rear. IMHO, you want the weld-in version (who ever makes them).
I know that MM sells a rear control arm with an adjustable perch. IMHO, get MM only!
IMHO, do NOT even push your car 1/2" if you put on the pure cr*p rear control arms that other companies sell. With the cr*p that other companies sell, you'll be lucky if the car can go 1" and not kill many innocent people, have your *ss sued to all hell, and so on.
The MM adj rear control arm isn't cheap (~ $450). But, along with the ploy isolators and 00-02 DOHC rear springs, you can get the rear of the car to the correct height.
XD Adj. Rear Lower Control Arms, 1979-98, with swaybar mount [MMRLCA-32] : Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader!
BTW: IMHO, you're better off going with poly isolators and the DOHC 00-02 rear springs and the adj rear control arm instead of just the adjustable rear control arm, stock GT rear springs, and stock rubber isolators.
Raising the mounting point of the rear spring does raise the rear of the car. However, the more you raise the spring mounting point from the rear spring, the more you effect the geometry of the rear suspension.
Good Luck!
J
Jack's95gt
443
Jun 8, 2010
  • Jun 8, 2010
lift rear springs
This past weekend I installed rear springs from a 2003 gt with some new isolators which gave about a 2" lift to rear of my 93 lx. The 99 - 04 gt rear springs are rated 210 lbs / in.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
SOLD For Sale '92 LX Street/Drag car - WV
  • MikeyMustang
  • Apr 12, 2025
2K
Fox Body Mustangs For Sale (1979-93) Dec 31, 2025
MikeyMustang
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
