Help Me Spend My Money!!
  • Thread starter Thread starter Scott7512
  • Start date Start date Jan 18, 2018
Scott7512
153
Branchland WV
Jan 18, 2018
  • Jan 18, 2018
I have just came up with $1500 to spend on my 93 5.0 lx hatch. The car has a stock bottom end with P heads ,1.6 rockers, electric fan, explorer intake and a X303 cam. CAI, 130 amp alt, MSD ignition and a chip. Short throw shifter. Full exhaust system. 3.55 gears and ford racing driveshaft. SVO front brakes with hawk pads and rebuilt rear drums.I also have all of the chassis braces and rear control arms. The interior has also been redone. The paint
is about a five footer or 8 of 10.
Should i get:
1) New intake
2) Rear disk brake conversion
3) Affordable heads and shaft rockers
4) 150 shot of nitrous
5) Save up for a stroker short block
6) Save up for a paint job
Mustang5L5
Mod Dude
Feb 18, 2001
43,349
18,085
224
Massachusetts
Jan 18, 2018
  • Jan 18, 2018
I could put together a nice 13" Cobra front And rear disk setup for $1500
Reactions: Davedacarpainter, Mstng93SSP and 2000xp8
General karthief
Mod Dude
Aug 25, 2016
28,114
10,733
213
polk county florida
Jan 18, 2018
  • Jan 18, 2018
#2 then #6
Or just send me the money and I'll tell you what I bought.
Reactions: RaggedGT
Scott7512
153
Branchland WV
Jan 19, 2018
  • Jan 19, 2018
Brakes it is. LMR has a rear disk kit for my 4 lugs. Under $800. Thanks.
General karthief
Mod Dude
Aug 25, 2016
28,114
10,733
213
polk county florida
Jan 19, 2018
  • Jan 19, 2018
And stangnet members get a discount at lmr
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Jan 20, 2018
  • Jan 20, 2018
i would do subframe connectors, MM rear lower control arms, Steeda spring and a good set of shocks along with the MM brake upgrade kit.
Reactions: deathb4dismount
billison
I like tinted tail
2,607
1,094
184
stl
Jan 20, 2018
  • Jan 20, 2018
$1500 can do a lot depending on goals and ability to sell things you upgrade. Depending on paint defects a good detail shop or possibly body shop could fix the current paint. Hit Craigslist , lots of intakes for cheap depending on your wants. I see almost complete 5 lug disc swaps posted regularly along with use nitrous. I see no reason you can’t knock out 2-3 of these or even look at aluminum heads and sell the p’s for one of the other upgrades.
Mstng93SSP
You have a nice rear end there Dave.
3,500
184
Mililani, Hawaii
Jan 20, 2018
  • Jan 20, 2018
I wouldn't pay $800 for a four lug rear disc brake unless for some reason you love the 4 lug rims. For $800 you could do a 5 lug, 4 wheel disc brake conversion if you plan right. I have done it a couple of times.
Reactions: General karthief
2000xp8
Aug 8, 2003
8,067
1,654
194
NJ
Jan 20, 2018
  • Jan 20, 2018
I thought the same thing at first, but after some thought if those 4 lug rotors could be swapped out later for 5 lug rotors it's not the end of the world.
As for price, I find half the fun is piecing stuff together as cheap as possible and then using the extra money to buy other stuff.
In this case I bet with some patience and creative shopping he could do a real 5 lug setup with second hand parts and get a set of 5 lug rims. Probably lose out on the tires though (maybe not, depends on who's unloading stuff that week.
I think for a grand I could find pbr fronts and do the rears. I think the wildcard would be the 94/95 spindles, they used to be $100 a set, don't think it's that way anymore.
Getting the brakes out of the way then the suspension is the right thing to do. 300+hp on a chassis and brakes that bad at handling 225hp is just a terrible idea.
Mustang5L5
Mod Dude
Feb 18, 2001
43,349
18,085
224
Massachusetts
Jan 20, 2018
#10
  • Jan 20, 2018
  • #10
Some guy on my local boards had 5 Bullitt wheels with tires for $150. Tires looked like they had a bit of life left too.
$800 for brand new spanking parts out back is fine. Hopefully that includes MC and booster. Paying to have a kit show up at your door and not search around is appealing for obvious reasons...and 4-lug 4wheel disk is fine if you are just cruising around town.
I actually don't mind the research and piecing together of parts. No idea what my setup costs as I've bought and resold parts along the way...but it works ok
88LXSleeper
146
56
48
Jan 21, 2018
#11
  • Jan 21, 2018
  • #11
Panhard bar and lowering springs and shocks.
stanglx2002
CT Material here
1,563
1,110
164
Jan 22, 2018
#12
  • Jan 22, 2018
  • #12
You never did mention what was the purpose of the car cruising, road course, drag strip, etc...
I would vote for brakes as well, since these cars stock can stop to safe your life. You can easily go an pull the front and back brakes from a 94-98 mustang, get some 94-95 spindles, pull the axles from rear, and then put S197 wheels/tires on the car to correct the backspacing of the rear. Sell the old stuff and you should still have extra money to spare.
I would also ditch that X303 cam as I know it isn't helping your performance. Go with a custom cam or at least a split duration TFS1 or Comp 270, and if you want more grunt then save to put a turbo on the car.
FoxMustangLvr
I love my Pimp
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Jan 22, 2018
#13
  • Jan 22, 2018
  • #13
Invest it in the stock market and thank me later. My ROI is up up up
(brakes)
N
newfoxfammember
GA
Sep 12, 2018
#14
  • Sep 12, 2018
  • #14
how do you get the discount?
Dan02gt
mazing how much gas smell came from that tiny hole
20+ Year Stangneter
Mar 2, 2003
909
415
113
Greenville, NC
Sep 12, 2018
#15
  • Sep 12, 2018
  • #15
Use code LMR6
Reactions: newfoxfammember and General karthief
Boostedpimp
20+ Year Stangneter
May 8, 2003
1,451
493
154
NJ
Sep 12, 2018
#16
  • Sep 12, 2018
  • #16
a used Strim
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Progress Thread "Alter Ego" White 1993 LX 5.0 5spd
  • idareu
  • Sep 9, 2024
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2025
idareu
help me understand calibrated maf sensors and injectors
  • stackz
  • Sep 21, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 7, 2026
AeroCoupe
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
