HELP ME!
  • Thread starter Thread starter Cobain03
  • Start date Start date Nov 7, 2004
Cobain03
996
Lexington, Ky
Nov 7, 2004
  • Nov 7, 2004
i recently installed a set of Tri y headers and i had to install the bracket that is required. so now my control arm is hitting my header on the drivers side. do they make soemthign special for this or what? i cant turn left shap and its hurtin my driving
HistoricMustang
2,359
Confederate States of America
Nov 7, 2004
  • Nov 7, 2004
What kind of bracket? I ran Tri-Y's for a few years and do not remember a bracket.
HistoricMustang
www.historicmustang.com
Cobain03
996
Lexington, Ky
Nov 7, 2004
  • Nov 7, 2004
its called a power steering bracket thing..it actually lowers a steering arm underneath so it doesnt hit the header
O
Ozsum2
695
  • Nov 7, 2004
......................and there have been some problems with it breaking due to metal fatigue.
Cobain03
996
Lexington, Ky
Nov 7, 2004
  • Nov 7, 2004
well what do you all suggest about my steering? i cant take sharp turns to the left and its killer trying to find a parkin spot easily enough to go into
HistoricMustang
2,359
Nov 7, 2004
  • Nov 7, 2004
I have got to back out of this one.
HistoricMustang
65Mustang2+2
118
Connecticut
Nov 7, 2004
  • Nov 7, 2004
Just buy the braket to lower the power steering! I think its like $20 every Mustang vendor sells them! Takes maybe 1/2 hr to install.
Route666
1,652
Brisbane, Australia
Nov 7, 2004
  • Nov 7, 2004
Hang on, he said he's already installed it. Does it hit the header without it installed?
6Stang7
1,470
Livermore, CA
Nov 8, 2004
  • Nov 8, 2004
Wait, what is it hitting? You said your control arm, but that is with suspension and is in your shock tower. Do you mean the pit-man arm? It goes from the steering box to your linkage right?
Cobain03
996
Lexington, Ky
Nov 8, 2004
#10
  • Nov 8, 2004
  • #10
yes the pitman arm is hitting the header pipe
the bracket that i installled was used to lower the hyd shock for the power sterring its ok its lower now but the arm on the sterring box
( pitman ) hits the pipe now when i steer to the left it was fine till i did the headers?????
6Stang7
1,470
Livermore, CA
Nov 8, 2004
#11
  • Nov 8, 2004
  • #11
Ya, that's normal. My pit-man arm hit my headers too. Simple, yet harsh fix. Get a hammer and have at it until it fits. You don't need a large dent, only a small one. However, it is still needed.
Cobain03
996
Lexington, Ky
Nov 9, 2004
#12
  • Nov 9, 2004
  • #12
there has to be another way why would thye sale headers that won't work ?? you know
65 fastback
1,347
Northern VA
Nov 11, 2004
#13
  • Nov 11, 2004
  • #13
That's why I'm running shorties now. My pitman arm hit my Tri-Y's, also. Changed motor mounts from '65 - '66, moved engine up, moved engine back, but could never get the header to clear the steering linkage. I had the exhaust shop cut the driver side Tri-y and weld in a "U" to allow for the steering linkage to clear.
Tim
none67
352
#14
  • Nov 11, 2004
  • #14
90% of all headers need some banging on when new. Its almost non-profitable to make headers for EVERY EXACT year and model. Headers are one of the must universal parts ever sold, mind you not like a carb or anything but you get my meaning. More common on new headers is to be banged on to fit clutch linkages. Anyway, it is the only way to fix it, and works good.
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Today at 7:51 AM
AlexM556
A
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
