Help!! MSD Distributor
92GTpony
18
I'm looking at summit rightnow and I'm looking to upgrade my distributor. One MSD distributor is Electric($281) and the other is mechanical($260). Im thinking that electric is for standard 5.0 and mechanical is for carb. Thanks...
My set-up....Stock 92 5.0, pullies, 3.73 gears, 65mm TB..
Not sure what exact models you are looking at but for the distributor to work with your stock computer and TFI ignition you need a distributor that works with TFI, they will be listed as such.
The electronic ones usually need an ignition box to work, the mechanical ones are pretty much drop in, with nothing else required.
if everything else is stock, why are you getting a new dizzy? just curious. the stock dizzy will work above any rpm your current engine will run. i would get a 6AL before i bought a dizzy, but i dont know your future plans.
My car has over 181k miles and the distributor is still stock. Just thought It would be a good time to change out to a good one. Eventually, I will be building a new engine when my current one dies. I have around $400 in cash to spend and I was going to get new MSD distributor, MSD wires and MSD TFI Blaster coil. Any thoughts?
Everything is stock :( except for 3.73 gears, pullies, 65mm TB, Cold air intake, and short shifter.
personally, i believe that the stock dizzy will last you a while. even a stock replacement one, the reason im saying this is that you could get a lot more out of the car for now if you bought an exhaust. if you arent having misfire issues or anything like that, i wouldnt worry about the dizzy.. just replace the cap and rotor with some good replacement parts (brass inserts) and maybe get a new stock coil.
your motor as it is (in my opinion) isnt going to require more than what the stock stuff can handle. i believe the stock dizzy can be reliable up to 6,000 rpms. someone correct me if im wrong. i guess if it was me, i would just do something you would notice a difference with.
if youre pulling your motor out eventually, i would wait and spend the money on the dizzy then, and do something now that you would notice a difference in, and a full exhaust would definately wake everything up a little, and you can transfer it to the new motor as well.
but like i siad, thats just what i would do. My buddy and i just swapped the motor from his 86 into his 90, and he bought an MSD dizzy as well, and its a very nice piece. but up untill now, he had the stock coil, a 6AL, and accell wires, and with his setup, went 12.7's.
all he had was an eddy intake, the original tfs heads, a crane cobra cam and street tires
