Ok here is the situation....
AFTER the car gets to normal temp at about 2000 rpm my car jus starts hessitiating then it will pick up and do it again... i havent noticed it doing it that much at higher rpms but i have felt it do it...it almost feels like its not getting gas thats the only way to describe it...
Here is what i have done to try to fix the problem so far...with no luck
255 pump
fuel filter
fuel pressure reg. Adjustable
MSD 6al
blaster 2 coil
auto lite 25 plugs .060 gap
new ford wires 9mm
Rotor and Cap
Throttle position sensor
So where do i go from here....someone told me (im not sure what it is called but it is facing the front of the car on the throttle body with a plug going to it) to take it off and clean it out with carb cleaner. Also to check my timing...but i dont know why all the sudden my timing would have anything to do with it when it only does it when the car is warmed up..
other stuff on the car
89 with 170,000 miles
24# inj with sensor
trick flow street intake manifold
70mm TB
full exhaust
Please help me...im running out of ideas and money
255 pump
fuel filter
MSD 6al
blaster 2 coil
new ford wires 9mm
Rotor and Cap
24# inj with sensor
70mm TB
full exhaust
