Help :( My Daily Driver Fox Is Having Backfire Problems
InMy88GT
Active User
Oct 22, 2016
17
Hey hows it going everyone? Well times passed and still my daily driver fox is having backfire problems. When i bought the car it didn't have any problems. A month later no problems, one day i drive out of the city 30 miles and arrive still no issues BUT on my way back 5 miles in im in 5th gear and pressing on the gas suddenly it feels as if gas wasn't flowing and the car began to backfire. I left off and gave it gass and still it backfired and i had a big losss of power. I gave it gas heavy and it pushed threw and the car ran fine, i parked the car at a gas station turned it off and it started fine and drove home that night.
1 month has passed Since then I've had the same problem every time i take the car out. I can be in any gear 1-5 and it'll backfire an lose power.i have noticed is it happens once the car has warmed up completely. I moved the timing to 10 and it seemed to lesses the backfire but still its accruing. I know my egr is working but does not have a hose running to it. Also my IAC is disconnected because it is bad, when i cold start the car it revs to 3000rpm and i found disconnecting it fixed that and the cat doesn't die with it unplugged.
Car has new plugs, wires, cap and rotar.
Please remember i drove the car for a month before this problem occurred. Only difference is my iac unplugged.
So car backfires loses power and only pulls smoothly when i apply gas.
I do not have a voltmeter to pull codes or the appropriate scanner at the moment so any help would be appreciated very much. Thank you for reading.
Replace the IAC valve....
Check the TP sensor...
Check your fuel pressure....
Change your fuel filter....
A back fire is unburned fuel in the exhaust...
Check the distributor...look below the rotor and window plate ( metal thing with square cuts in it ) there's a sensor ( PIP sensor )....does it look soft and fuzzy...does it move if you lightly touch it with a screw driver.
Its hard to help someone like you. You know the car has known issues but continue to drive without fixing them....then you get on here and ask for help.
If I was there the easiest way to help you would be to take your keys and keep you from driving it until you can fix it. One problem leads to another....and another...and another.
I'm completely down to help people that are willing to help themselves. A multimeter is 7 to 13 bucks.
Reactions: 2 users
All you need to read the code dump on an 86-88 Mustangs a test light and a paper clip.. You need to dump the codes before guessing at anything.
Backfiring out the intake is and entirely different thing from gas popping and burning in the exhaust.
Backfiring out the intake is either a valve stuck open or a lean mixture or spark plug wire(s) connected to the wrong cylinder(s). Check compression on all cylinders and then look for vacuum hoses loose, cracked, or misconnected. Check the line for the vapor recirculation system – it is easy to knock loose and not see it when you connect the air pump plumbing. If the vacuum line for the EGR valve and the air pump are cross connected, some very strange things can happen. Check the mass air flow electrical connection and see that it is tight, the same goes for the fuel injection wiring harness connectors up on top of the manifold near the firewall.
Sticking valves: If a intake valve is bent, has a bad spring or is misadjusted, the engine will sometimes backfire through the intake. Use a vacuum gauge connected to any convenient spot on the intake manifold. Run the engine at 1000 RPM & look for 18-21 inches of vacuum with a steady needle. A problem intake valve will make the vacuum gauge needle sweep 5-10 inches.
Lean fuel mixture breaks out into several sub categories:
A.). Vacuum leaks
B.) Air entering the intake without passing through the MAF on Mass Air cars (89-95 models).
C.) Failure of the MAF, BAP/MAP (Baro or Manifold Air Pressure, same sensor, different name), ACT (air charge temp), or ECT (engine coolant temp). These should set a code in the computer.
D.) O2 sensor problems: one or both O2 sensors with low output or bad O2 sensor heater ground. This should set codes 41/91. The O2 sensor heater ground is an Orange wire in the engine mounted fuel injector harness. Ground it to the back of the head or intake manifold.
E.) Leaking exhaust gases from EGR valve at WOT or EGR opening when it should not be open.
F.) Poor fuel delivery due to bad fuel pump, clogged filter or bad fuel pump wiring. Look for low pressure or fluctuating pressure. Standard injector pressure is 39 PSI at idle, with the vacuum line disconnected from the regulator and capped.
G.) Clogged fuel injectors.- see the cylinder balance test below
H.) Fuel injector wiring problems causing injector not to deliver rated flow (dirty or stuck shut injectors).
I.) Computer problems: (computer problems are not common like sensor problems)
J.). ROM has bad data in fuel or timing table. This should also set a code in the computer.
K.) Failure of one or more of the computer's driver transistors for the fuel injectors. No code set on this one. Use a noid test light to test the injector wiring & injector drivers,
L.) MAF calibration off or mismatched to injectors.
M.) ACT or ECT bad. Sometimes the sensors will be off calibration, but not bad enough to set a code. If they falsely read too high a temp, the engine will back off fuel delivery.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
Vacuum leak due to slipped lower intake manifold gasket...
Ask Nicoleb3x3 about the intake gasket that slipped out of place and caused idle and vacuum leak problems that could not be seen or found by external examination. I don't care what you spray with, you won't find the leak when it is sucking air from the lifter valley. It simply isn't possible to spray anything in there with the lower manifold bolted in place.
photodisplay.php
Cylinder balance test:
See the procedure below to dump the codes and place the computer into diagnostic mode.
Warm the car's engine up to normal operating temperature. Use a jumper wire or paper clip to put the computer into test mode. Start the engine and let it go through the normal diagnostic tests, then quickly press the throttle to the floor. The engine RPM should exceed 2500 RPM's for a brief second. The engine RPM's will increase to about 1450-1600 RPM and hold steady. The engine will shut off power to each injector, one at a time. When it has sequenced through all 8 injectors, it will flash 9 for everything OK, or the number of the failing cylinder such as 2 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures. Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should. See the Chilton’s Shop manual for the complete test procedure
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Reactions: 1 user
I never knew you could do a cylinder balance test like that. I have a Snap-On Solus scanner. Are the KOER and KOEO tests doing the same thing? What do those tests do? I hear solenoids clicking on the KOEO test.
The KOER test also asks to turn the steering wheel along with pressing the clutch pedal, what is the purpose of that?
That's just a way for the computer to know your in a diagnostic mode while running the engine.
Wouldn't want to go into a koer test by mistake driving down the road.
