HELP! need help w/ grille delete
if they are the ones underneath then you will have to bend you bumper(it bends pretty far) and unscrew them from underneath. It is kinda scary doin it but its the only way without having to take the whole bumper off
Hunter-White Those two screws that are left just screw and screw but don't go anywhere. I don't know how to get them out?[/QUOTE said:
It seems to me that the nut on the back of the screw may be loose but if that's so i'm not sure what to do about it
anybody else have any ideas
Those aren't screws. They are push pins. I know they have screw slots in them but they never work and always strip. As soon as you get one out it will all make sense. Just get some needlenose piers or a knife and pry them up or pull them out. Don't worry about breaking them, they are cheap and no longer needed
Nice mod, you'll love the end result with a silver GT
Those two screws that are left just screw and screw but don't go anywhere. I don't know how to get them out?[/QUOTE]
all you need to do is pry a small screw driver under the screw part of those push pins while unscrewing them. that happens all the time with those. it's just a push pin with a screw in the center that pushes the sides of the pin under the screw outward.
