HELP...Need Info ASAP!!!
  • Thread starter Thread starter Fresh GT
  • Start date Start date Apr 24, 2004
F
Fresh GT
486
SoCali Stanger 4Life: San Diego/Temecula, CA
Apr 24, 2004
  • Apr 24, 2004
I am looking to buy what is offered as a 68 GT Fastback with Vin#8R02C114782. Any way I can tell if this is a REAL GT Fastback and not a wanna-b??? Any help is greatly appreciated and I'll take you for a cruise if I get it too!!!
Fresh
R
Ronstang
1,294
Houston Texas
Apr 24, 2004
  • Apr 24, 2004
I thought "09" was the body code for fastback....unless they changed it in 68.
F
Fresh GT
486
Apr 24, 2004
  • Apr 24, 2004
I don't know enough about the older Stangs. I wish I did cause I wouldn't be in this situation now...lol
M
mustang466
20
  • Apr 24, 2004
There is no way to tell from the vin or door tags.Look to see if it has dual exhaust with the factory hangars.Also it should have factory front discs with 5 lug pattern and mine has a 9 inch but I dont know if they all had a 9".Also if it has factory fog lamps in the grill.These are a few ways to tell.
Bob
F
Fresh GT
486
Apr 24, 2004
  • Apr 24, 2004
Ok...thanks...Next questions is how to tell if it's Factory or aftermarket add on, etc.
Snail50
787
Miami
Apr 24, 2004
  • Apr 24, 2004
I don't think the VIN will indicate if it's a real GT.
Does it have:
GT rims
Pop-open GT gas cap
Dual exhaust cutouts on lower valance
Grille fog lamps
Chrome side marker and reflector trim
GT emblem on the sides rather than "Mustang" script.
If so, it's either a real GT or someone spent a lot of time making it look like one. Also, Mustangs could be purchased from the dealer with any or all GT options, and still not be a "real" GT.
the one you're looking at came with a C code V8, which was a 289 w/2V. I don't know if a 68 GT could be had with a 2V V8; someone chime in here?
Snail50
787
Miami
Apr 24, 2004
  • Apr 24, 2004
67 and 68 fastbacks were "02," changed from "09" for previous years.
Snail50
787
Miami
Apr 24, 2004
  • Apr 24, 2004
Bob
Not sure, but I think GT's could be had with drums as well.
3spd on floor
1,099
Acworth, GA
Apr 24, 2004
  • Apr 24, 2004
i'm 99% sure there were no C code GTs(definately not in 65-66). but if its not a GT, who cares? its still a mustang and is still awesome.
F
Fresh GT
486
Apr 24, 2004
#10
  • Apr 24, 2004
  • #10
Ok...here's what I have found out:
C Code is a 2 Barrell 289
J Code is Stangard 302 4 Barrell
X Code is rare 390 2 Barrell
S Code is 390 4 Barrell
R Code is 428 CJ
Thanks to all who responded and tought me what to look for!!!
~ Fresh
67GTA-FB429
777
Tri-Cities, Wa
Apr 24, 2004
#11
  • Apr 24, 2004
  • #11
a GT "C" code?!? That would be very rare IMO. But in 67-68, you could get a plain-jane fastback with all of the GT bits....but no GT badging (I think). The options were very variable not like today.
Does the engine numbers match the VIN?? If so, pull it and swap motors, if not, who cares.
67GTA-FB429
777
Tri-Cities, Wa
Apr 24, 2004
#12
  • Apr 24, 2004
  • #12
Also: my GT has front discs and rear drums and no lower console or foglights (but it has been in some wrecks before my ownership).
It is a crapshoot
M
mr-fixit
466
Malvern,Pa.
Apr 25, 2004
#13
  • Apr 25, 2004
  • #13
In 1968, the J code (302 4V) was the base engine for factory GT Mustangs. A couple things to look for when hunting down a real GT, check the fog light wiring harness. It should have factory style plugs at the fog light end, (the reproductions are easy to spot) and it is routed in with the main wire loom, not added on. And as mentioned before, the factory dual exhaust hangers have reinforcements welded to the floor pans where they bolt to,this is overlooked on most GT conversions.
Snail50
787
Miami
Apr 25, 2004
#14
  • Apr 25, 2004
  • #14
Because if it's a "do-it-yourself" GT, and the seller is asking "real" GT $$$, then Fresh can use that as negotiating leverage.
THis is a tough one though, because it takes some real digging to find out if it's a factory GT.
BTW, how much is the seller asking, Fresh? And more about the car. Color, condition, trans, interior/exterior options? Do you have the data plate info as well? That will tell more about the car's originality.
Snail50
787
Miami
Apr 25, 2004
#15
  • Apr 25, 2004
  • #15
Also, does the car still have a 2V 289, as indicated on the VIN?
Another feature of the GT package was a thicker-diameter front sway bar. I don't know the what that "thicker" diameter is, but the stock front sway on my non-GT 67 was approx. 5/8". Hope this helps.
M
How To Decode
  • Malcoll1
  • Mar 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2026
FoxChasis
F
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
ECU help!
  • starkiller1134
  • Aug 16, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2025
starkiller1134
R
Need a little help identifying this plug
  • redlineracing1328
  • Oct 7, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 8, 2025
revhead347
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
