  • 1994 - 1995 Specific Tech
HELP!! need tranny Info please!
  • Thread starter Thread starter OrangeMustangGt
  • Start date Start date Apr 6, 2004
OrangeMustangGt
1,976
Cape Cod, MA
Apr 6, 2004
  • Apr 6, 2004
here is my problem: my tranny is whining in 3rd, and it always has, BUT recently it pops out of 2nd gear on down shifts. I have been checking out some options, I could rebuild the tranny with a kit, like in jegs, or mustangs unl't, but WHAT does thus kit include, and will it fix my problem?($250), 2nd, i tried to find a new tranny in magazines, like summit, etc but all they have are t-5 that say will not fit 94-95. Also, the tremics say they wont fit our cars! I realize that out trannys are different from the fox trannys but why and can they be made to fit? Lastly, i was thinking junkyard....obviously the 95-95 cars have compatable trannys, but are there any newer cars that have trannys, t-5 that will bolt right up, due to milage on the 94-95 cars. Thanks!!!
blackEagle
116
Calumet City,IL
Apr 6, 2004
  • Apr 6, 2004
In order to use a 87-93 trans, you need a 87-93 bell housing and clutch fork. You will also need a D/S spacer as the FOX trans is shorter. When you purchase a Tremec, most shops will also sell you the parts for it to work in our cars.
Check with Hanlon motorsports or D&D performance. They should be able to tell you what you need.
OrangeMustangGt
1,976
Cape Cod, MA
Apr 6, 2004
  • Apr 6, 2004
ahh, i see the drive shaft spacer...ahhh
ChromeYellow94
937
Holland Michigan
Apr 6, 2004
  • Apr 6, 2004
besides the basic rebuild kit you're for sure gonna need a new input shaft and 2nd or third gear....Had the same stuff done on my t5 in my 94 and it cost over $600 from D&D performance. The tranny then blew up about a month later. T5's are junk and don't put a dime into it. Just get the tremec.
Here's what I got for the swap.
Aluminum Tremec bellhousing.....Fit's perfect....unlike some steel ones...
Tremec3550
D&D shifter (same as steeda...literally)
driveshaft spacer
Clutch fork
TO bearing'
Gm synchromesh fluid.
new speedo gear.....Tremec's have a better 7tooth drive gear unlike the stock 8tooth so you need a different driven tooth to keep your speedo correct
It was like $1800 total. Swapped in like 2 hours on the lift.
OrangeMustangGt
1,976
Cape Cod, MA
Apr 6, 2004
  • Apr 6, 2004
wow damn, thats what im gonna have to do, too bad i just bought a pro-5.0 shifter. can i use my clutch? for all that money, maby ill just rebuild mine myself/ i aint scared.
blackEagle
116
Calumet City,IL
Apr 6, 2004
  • Apr 6, 2004
The April Car Craft has a pretty good article on manual trannys. It has some specs on the Tremecs andd contact info for the various companies.
ChromeYellow94
937
Holland Michigan
Apr 6, 2004
  • Apr 6, 2004
yes the splines are the same as stock on a 3550. It is worth every penny. Tremecs shift so awesome...CLiCK CLiCK.....
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
R
New Member, needs help with built '04 engine
  • rollo19
  • Aug 6, 2025
  • The Welcome Wagon
The Welcome Wagon Aug 6, 2025
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
