I tried searching, but can't get a definate answer. So, thought maybe someone has a combo similar to mine and can chime in. And would like some ideas on what manifold I should get the best results so my heads can breath right.
Mods: 331 cubes, 8.8 comp ratio, AFR185 heads, 1.72 rockers, 80mm pro-m, 30# injectors, basanni exhaust all the way to the back, and 9 psi of boost. Boost will most likely go higher in the very near future too.
So what do you guys think the best manifold would be that suit my needs? The car pushes over 400 rwhp, (dyno'd over 400 with my old gt-40 heads) so my Cobra intake I think has served its purpose and I think is choking my car now instead of helping. I heard the Cobra intake is only good for about 350 rwhp right? I have heard the Trickflow Track Heat is pretty good, any truth to that?
Any opinions welcomed
thanks
thanks
From the outside it still looks factory stock.
