help needed with no spark
  • Thread starter Thread starter BeerElf
  • Start date Start date Aug 16, 2006
BeerElf
85
Hillsboro, OR
Aug 16, 2006
  • Aug 16, 2006
Car died when I came to the corner of my block. I heard a click or tick and then wouldn't restart. Pushed it back home and checked spark to the plugs and there was none. Then checked spark from the coil and none.
Also when trying to start the car the tac freaks out and spins backwards. I'm thinking it's either the coil or the computer.
Also tried disconecting the msd 6al and same thing.
Any suggestions on how to diagnose the problem?
-Craig
billison
I like tinted tail
2,607
1,094
184
stl
Aug 16, 2006
  • Aug 16, 2006
i'd toss a coil in it and go from there, does it get power, find where the power stops and fix it
795.0pacecar
lover of pudgy polygamists
Jul 11, 2003
480
Senoia, GA
Aug 16, 2006
  • Aug 16, 2006
TFI module, normally when they go they completely die and you will get no spark.
HISSIN50
34
129
Aug 16, 2006
  • Aug 16, 2006
Check injector pulsing if you have a noid light (or an LED test light). The PIP came to mind for me.
Good luck.
BeerElf
85
Hillsboro, OR
Aug 17, 2006
  • Aug 17, 2006
PIP had died once in the past, but I also just put in a new msd distributor. So I don't think that or the TFI is it. Guess I can try a new coil.
Also just checked the codes. Got the following:
14 - Electronic Control Assembly (ECA) detected intermittent loss of PIP signal
18 - loss of tach signal to ECA
87 - fuel pump relay circuit failure - I can hear the FP running
BeerElf
85
Hillsboro, OR
Aug 17, 2006
  • Aug 17, 2006
I don't have a noid or LED test light. only a volt meter and timing light. Any way to test the injectors without one?
795.0pacecar
Jul 11, 2003
480
Senoia, GA
Aug 17, 2006
  • Aug 17, 2006
The codes indate a TFI or PIP failure. Im sticking with TFI, but it is very likely it could be the PIP. Just because its a new distributer doesn't mean the electronics on it are good. I've heard of people having problems with the TFI on MSD distributers.
HISSIN50
34
129
Aug 17, 2006
  • Aug 17, 2006
You can try it with a simple old test light. If you dont have one, you really need one. They're like 3-7 bucks at the parts store. Harbor Freight puts them on sale for a buck all the time. The test light will do something if you have 12 volts and ground pulsing. If the test light is dead, chances are it's not picking anything up.
I'd ask if the click or tick sounded like it could be an electrical item popping (link burning, fuse blowing - that kind of sound)? I didnt know if it was that or just the starter trying to turn-over.
Good luck.
BeerElf
85
Hillsboro, OR
Aug 17, 2006
  • Aug 17, 2006
The tick happened when the care was coming back to idle at a stop sign, so it was not the starter. At first I thought it might be a fuse, but I don't think it is unless it's one of the fusable links coming off the starter solenoid.
I'm going to pick up a test light and a coil tonight and see what happens from there.
Thanks!
Craig
HISSIN50
34
129
Aug 17, 2006
#10
  • Aug 17, 2006
  • #10
My bad - I misread and thought it ticked when you tried to restart.
Post up what you find from testing. A bad PIP (as well as a bad TFI) will also keep you from seeing a ground pulse at the coil (it should have key-on 12 volts). If you put a test light across the two coil terminals, the test light will flash super fast.
Good luck.
BeerElf
85
Hillsboro, OR
Aug 18, 2006
#11
  • Aug 18, 2006
  • #11
Well, did some more work last night and discovered that the new distributor seized and was not spinning! Guess that would cause no spark... Needless to say it's getting sent back today. Hopefully the next one will work better and I'm be back in business soon.
billison
I like tinted tail
2,607
1,094
184
stl
Aug 18, 2006
#12
  • Aug 18, 2006
  • #12
that sucks
HISSIN50
34
129
Aug 18, 2006
#13
  • Aug 18, 2006
  • #13
How bad was the carnage? If the dizzy wasnt spinning when you cranked the motor, something had to give...........
795.0pacecar
Jul 11, 2003
480
Senoia, GA
Aug 18, 2006
#14
  • Aug 18, 2006
  • #14
I would guess the cotter pin on the gear?
BeerElf
85
Hillsboro, OR
Aug 20, 2006
#15
  • Aug 20, 2006
  • #15
checkin it out tomorrow... will let ya know...
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
  • dan50
  • Jul 18, 2026
dan50
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
