Help needed :/
94 Mustang SVT
Hi, i have a 94 cobra, i have a e303 cam in it i heard i can get my cam to go straight to idle if i change the computer out to a 89 fox computer and a msd ignition, i just wanted to get a little more info on this or maybe someone could help more on this. when i stop, the car will idle high for maybe 5 seconds then finally the idle will drop, also my car is burning oil, thinking it may be the heads, thats what im hopeing it is, did a cylinder check on all 8... 1-7 were anywhere from 130 to 140 but #8 was 110 also i have oil in my intake tube all the way down to the Mass air flow, im hopeing its just the heads
thanks for your time and help
Ron
Hey Ron, :welcome: to :SNSign:
The A9* swap is typically frowned upon around these parts, but with good reason. I'll put together a list of pluses and minuses from the things that I know of for you.
Pluses (A9*):
1. More mod friendly, to a point (the Fox guys/gals aren't immune to surging/drivability issues)
Minuses (A9*):
1. Still a stock tune, no matter how you spin it
2. May still need a tune, at the same cost of tuning the stock EEC
3. Need to purchase an aftermarket fan controller (A9* doesn't have the capability)
4. Older, slower processor
5. Need to re-pin EEC harness for swap (or purchase adapter)
And the pluses/minuses of keeping the stock EEC:
Pluses (J4J1):
1. Newer, faster processor
2. No mods necessary to keep
3. Don't need an aftermarket fan controller
4. Any drivability issues can be overcome with a tune, the same as with the A9*
Minuses (J4J1):
1. Less mod friendly when stock
I'm personally a believer in tuning the existing EEC. The choice in how to do so is totally up to you. I went with a TwEECer RT to self-tune, but there are other options available, such as the Anderson PMS, having a shop do a dynotune, or mail order chips from a reputable tuner.
Now on to your next issue. A leakdown test would give you a better indication of where the issue may be with the number 8 cylinder. Were the results performed dry? How does the compression look in the number 8 cylinder if you squirt a little oil into the cylinder and repeat the test? How does the plug look on that cylinder when compared to the others? 20-30psi difference between the cylinders may be significant if there's some sort of mechanical issue like worn rings, cracked ring land on the piston, or a broken ring itself. What I would recommend, and personally do before anything else is to clean up the oil as best I could, install a new PCV valve, and probably install an oil separator to see if the oil burning issue persists.
my friend is getting that tester for me so i can do it this weekend, i have a jasper motor i heard a lot of bad things with the rings in those motors. im hoping its the heads because my friend has patriot heads i may be able to get off of him
i have had the car tuned when i got the cam installed i don't know whats done to that computer maybe someone messed it up a lot of people around hear have that computer swap, i glad you were able to explain it to me might start building that 408 i want
i thank you for taking the time and replying
Ron
Hi Ron :D
Mr. Matt has done a good job of laying it all out for you :hail2:
I've fooled around with the pcm's in these cars a bit myself :)
So ... I would echo what he said :D
If you want to see more info about the 94-95 Fox pcm retro fit .....
you can do a search using A9L or PIH and be sure to focus the search
to the 94-95 tech and tuning forums.
Tons and Tons of info :crazy:
and
Peeps opinions about why OR why not to do it ;)
Grady
Ron
Just went through the same thing. #8 was 100 psi with 1-7 in the 145-150 range. #8 leakdown test confirmed a ring issue. Hope yours are heads only, I wasn't so lucky. I'm wondering if this is a common problem and is somehow related to design as it's my understanding that #8 tends to run lean on our cars.
