- Mar 30, 2006
- 8
- 0
- 0
Howdy all, I was wondering if anyone could help. I have an 89 mustang with the 5.0. I decided to rebuild the motor before putting the trick flow kit on. Had the bores punched .030 over and had new pistons pressed on the stock rods. The pistons that the machine shop got me were sealed power 273AP's. Has anyone used these pistons with the Trick Flow kit? The reason I ask, I started checking the valve clearence and I think the valve is hitting the top of the piston. What I did was torque the head to 30 ft. lbs, Install the #1 intake and exhaust lifters, pushrods, and rockers. Set the lash on the rockers (spin pushrod while tightening the rocker till no free movement, then tighten an additional 1/2 turn), then I started spinning the motor by hand. As soon as I felt some binding I stopped and removed the head. I do not see any marks on the head or the top of the pistion though.
Any thoughts would be great and thanks in advance
Dave...
Dave...
