HELP no spark off coil!!
Teal_Deal
ok so i was driving to school yesterday when the car just completely died. now the car is turning over and Its getting fuel but no spark. so i replaced the coil. that wasnt it. so i looked on here and people were saying to replace the TFI sensor so i did that. still nothing. im running out of ideas of what it could be. there is no sparking coming from the coil but i have put 2 different ones on and nothing works. when i checked with the multimeter it said that there was 12v going to the coil but im not really sure on how to use the thing i could be doing something wrong cause that wouldnt make sense. thanks guys.
Use a test light biased across the electrical connector to the coil. DMM's give inaccurate readings for a test like you're doing.
See Jrichker's no start checklist for a systematic means of testing. It will save you money in parts swapping.
Good luck.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
Revised 29-Jun-2007 to update TPS testing procedure for 94-95 Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. See paragraph 5A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire with the switch in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position, then the fuse link is blown.
H.) Computer
J.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
attachment.php
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) A noid light available from any auto parts store, is one way to test the injector wiring.
The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.99 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
I say just pull your distributor and buy a new or reman from auto zone, same thing hapened to my car and people kept saying to chech this and check that, but I couldn't find anything wrong with mine, so I just bought the new distributor and it fired right up, I think there around 60 dollars, just kep your caps and tfi module.
im with dcurtis, i had a problem like this and it was the eye in the dizzy that tells the tfi to signal the coil to fire. i had the magnetic eye fixed but i still think i need a new dizzy.
Sry to bring up an old post. But Im running threw the no start list and im at the point on checking my tps. Checking my ohm rating of my ground wire (black/white) and its reading like 5.0+. Aswell as my injectors are only at 8-9v +-. I checked the ground on my eec sanded off old pant and made sure it was clean metal. Battery is in the trunk i have 1 ground running to frame and 1 to roll cage. and i have solid motor mounts.
When i spray some engine starting fluid the car seems to want to start realy bad. I guess i should mention this is a explorer motor i put the tfs stage 1 came in, with usual bolt ons. Its a reman distributor from advance. Now ive never done any of this type of work but ive spent allot of time watching and reading on how to. The car hasn't ran in about 12 years. I chopped up my old harness cause i decided to go carb. After a few years decided to go back.
The maximum resistance on The black/white wire should be less than 1.5 ohms. Be sure to take rsistance readings with the ignition switch off.
Check and clean the salt & pepper 10 pin electric connectors. See http://oldfuelinjection.com/?p=85 for the how to do it with pictures.
See the graphic for the 10 pin connector circuit layout.
salt-pepper-10-pin-connectors-65-jpg.68512
The injector power pin is the VPWR pin in the black 10 pin connector.
Ok all is clean. still only seeing 8v on both wires going to the injectors. car started for a second with a shot of starting spray so i know this has to be a fuel problem. Im running all braided line up to a professional products fuel rails and regulator both the rail mounted fuel pressure gauge and cock pit gauges are reading 35 lbs.
Are there fresh batteries in your voltmeter?
If there isn't 12 volts on the red injector wires, you have a low voltage condition in the power feed circuit for the computer. The computer power feed relay also feeds the red wires for the fuel injectors. There is a voltage regulator inside the computer to supply 5 volts to all the computer circuitry and some of the sensors. If the voltage drops off too far, the voltage regulator inside the computer quits working and you will see strange voltages on the TPS ,MAP/Baro and EGR sensors.
Diagrams courtesy of Tmoss & Stang&2birds
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
Ok after alot of yelling, kicking, and screaming.. Somthing told me to try my old eec relay. and wham! 12v to injectors!. still doesnt start though so im gonna buy a noid light tomorrow and make sure it flashes. And if thats good im gonna pull my timing cover off again and make sure i set my cam gear timing correct.
Ok news update. so i did some more readings on my tps, and blk/w ohm reading with key off is 5.69. now ive moved the battery to my trunk so i cant get a negative lead straight from that but i went to motor. also pulled a wire straight from there and same reading. Ok now my volts from orange to blk/w was .15v but from orange to motor was 9.67. now my volts from blk/w to green was .13v. but from motor to green was 9.98v. i also did the blk/w to green and move the throttle and there was only a .8v change at wot.
Now obviously it seems theres a ground issue here. Ive check all the grounds i could find. Also my haynes manual says pin #20,40,60,49 are all grounds. So i did a ohm reading from them to my eec ground and 2,49 was .02 ohm. pin 40 and 60 are showing 47.5 ohm.. Can i just jump all these together for 1 known good ground. This tps issue would have to be the reason my injectors arnt firing since its reading so high?
