Help!!! No Turn Signals
  • Thread starter Thread starter 93gtmustang
  • Start date Start date Oct 20, 2007
93gtmustang
524
43
49
Oct 20, 2007
  • Oct 20, 2007
I just lost my turn signals.
I checked fuse #5. It was not blown.
Any ideas on what else to check?
Thanks
93gtmustang
524
43
49
Oct 20, 2007
  • Oct 20, 2007
Just pulled my car in the garage and they started working again.
Maybe something loose in the steering column?
93gtmustang
524
43
49
Oct 20, 2007
  • Oct 20, 2007
Turn signals are still working but there are no back-up lights, and they are on the same fuse.??????????????
93gtmustang
524
43
49
Oct 20, 2007
  • Oct 20, 2007
Pushed in on the plug going in to the trans. on the drivers side.
I've got reverse lights. It must have got loose from hard launches.
93gtmustang
524
43
49
Jul 21, 2008
  • Jul 21, 2008
Lost my turn signals again!!!!!
I have back up lights.
Help!
Thanks
JKidd
164
Suffield, CT
Jul 22, 2008
  • Jul 22, 2008
Check to see if your HVAC controls work.
If fuses are OK, you might want to look hard at the ignition switch (inside steering column). Rather common issue (apparently).
ID89GT
1,659
18
49
Spokane Valley, WA
Jul 22, 2008
  • Jul 22, 2008
Could be a hazard switch, I know that if that is faulty on some cars the turn signals tend to go off and on
LX302
Stanger
728
Bethlehem PA
Jul 22, 2008
  • Jul 22, 2008
Right, does your fan work? If not, then take off the plastic panels under the sterring wheel.
A long beige plug attached to the steering column usually comes loose with time. Plug it back in and wire tie to keep it coming loose again.
93gtmustang
524
43
49
Jul 22, 2008
  • Jul 22, 2008
What are HVAC controls?
The Hazards work. Are the hazards same thing as hazard switch?
Just checked my fan. It works. Heater fan right?
I'll check the steering column next, or should I bother if the fan is working?
Thanks for all the help!
1993 GT Mustang / Ford Racing GT-40 Crate Motor B-303 Cam / 24 lb. Injectors / Stock Ignition / MSD EFI Blaster Coil / Edelbrock 5.0 Upper and Lower Intake with BBK Phelonic Spacer / Professional Products 70mm Throttle Body / C&L C.A.I. w/76mm MAF / Stock Air Box w/K&N Panel Filter / Holley Adjustable Fuel Pressure Regulator / Electric Fan / BBK Underdrive Pulley's / A.C. Removed / BBK Short Headers / Flowmaster Exhaust / Tremec T-5Z / B&M Short Throw Shifter / Alum. Driveshaft / 4.30 Gears / Eaton H.D. Posi / Moser 31 Spline Axles/ Subframe Connectors / Line Lock / Driveshaft Loop / BMR Upper and Lower Control Arms / Lakewood Adjustable Drag Shocks/ Holley 190 lph Fuel Pump /
67coupe
658
402
93
Huntsville, AL
Jul 23, 2008
#10
  • Jul 23, 2008
  • #10
Yes, everyone is talking about the blower fan for your A/C and heater.
Next time the turn signals stop working, check the blower fan to see if it's working.
When the ignition switch in the steering column goes bad, the turn signals and blower fan will stop working.
BTW, I had this problem a few months ago. It would come and go at random times. So, next time the turn signals stop working, be sure the check to blower motor.
93gtmustang
524
43
49
Jul 23, 2008
#11
  • Jul 23, 2008
  • #11
The blower fan is currently working and the turn signals are not working.
What next?
Thanks for the help
93gtmustang
524
43
49
Jul 23, 2008
#12
  • Jul 23, 2008
  • #12
Could this be the problem?
I found the flasher unit in the radio compartment.
I put an ohm meter on both terminals and I have no signal.
Any help would be greatly appreciated
Thanks!
67coupe
658
402
93
Huntsville, AL
Jul 23, 2008
#13
  • Jul 23, 2008
  • #13
I would replace that as a first step. Seeing as your HVAC blower works, it's very unlikely that the ignition switch is bad. I think you're on the right track (mines never gone bad), I would go ahead and replace it.
93gtmustang
524
43
49
Jul 24, 2008
#14
  • Jul 24, 2008
  • #14
It was the flasher unit.
Turn signals are now working!
Thanks everyone!
JKidd
164
Suffield, CT
Jul 25, 2008
#15
  • Jul 25, 2008
  • #15
Good deal. Glad you got it fixed.
Thanks for the follow up.
Anaconda
107
Memphis, Tn
Jul 25, 2008
#16
  • Jul 25, 2008
  • #16
Glad you found your problem, now I have the same issue on a 89GT. I have checked all the things listed, could not find a a flasher. The hazards work fine, I have a extra turn signal & swapped it out & still no signals. HELP!!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 25, 2008
#17
  • Jul 25, 2008
  • #17
The flasher is not mounted on the front of the fuse panel. The flasher on the front of the fuse panel is a separate one for the hazard lights. It is in one of several places, depending on when your car was made. Some are behind the fuse panel on the back side, others are behind the radio and some are behind the glove box.
Other possible problem sources for the turn signal malfunction are the ignition switch, multifunction switch and the plastic shell that holds the turn signal wiring connector pins.
A word of caution about multifunction switches is in order here. The multifunction switch (high/low beam, wiper, turn signals) are different for different years. 87-98 will work in any 87-89 car. The 90-93 switches only work in 90-93 cars. You can't put an early model switch in a late model car, nor can you put a late model switch in an early car.
Supposedly you can move the pins around to make the switches work in model years that are different from the car the switch came out of. I cannot verify that and haven’t tried it .
The following diagram is for 87-89 model cars.
Turn signal switch wiring:
Electrical Turn Signal / Lights Issue
  • 86SilverFox
  • Jun 2, 2025
Fox 5.0 Mustang Tech Jun 3, 2025
General karthief
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
Fox Turn signal flasher keeps failing
  • keel
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
68 headlights hot working
  • Butchd88
  • Aug 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 3, 2026
Butchd88
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
