  • 1994 - 1995 Specific Tech
help on choosing cam
  • Thread starter Thread starter jamez1502
  • Start date Start date Dec 1, 2004
J
jamez1502
Banned
Nov 6, 2003
135
Lakeland Fl
Dec 1, 2004
  • Dec 1, 2004
What is a good cam to go with with my current setup. I want to do a cam now. It will be a while on getting heads because i have to save money. so any ideas on cam swap woeld be great
Joes95GT
3,132
Delaware
Dec 1, 2004
  • Dec 1, 2004
It's not a very worth while mod to put a cam on stock heads. If you insist, there are plenty of cams that will do OK. My preference of the day is the Crower 15511. It's a large enough cam @ .050 that it makes up for the small ports of the E7. I like some of Comp's grinds, too.
With either cam, because of the aggressive ramp rates, you will definitely have to change your valve springs because you WILL experience valve float and in Comp's case, you may even experience coil bind.
Joe
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Dec 1, 2004
  • Dec 1, 2004
With what you have I would just add 1.7 RR and call it a day.
J
jamez1502
Banned
Nov 6, 2003
135
Lakeland Fl
Dec 1, 2004
  • Dec 1, 2004
if i do a e303 cam and 1.7 rr will that help me or would theCrower 15511 be the better cam. it will be this summer sometime before i can afford heads
and would i also need to change valve springs
J
jamez1502
Banned
Nov 6, 2003
135
Lakeland Fl
Dec 1, 2004
  • Dec 1, 2004
one more thing which would i see a better gain with
Scott_95GT
387
Sacramento
Dec 1, 2004
  • Dec 1, 2004
As long as you get 1.7 rr's, and some valve springs, I think a mild cam would be a great addition to your setup. Obviously heads would be great as well, but not everyone has an extra 600-1000 dollars sitting around, including myself. Go for the cam.
ProKiller
3,064
15
78
PA
Dec 1, 2004
  • Dec 1, 2004
i would just get some 1.7 RR and call it a day. honestly, your going to see a whole lot from the cam on stock heads. save the money for the cam, and put it towards heads.
J
jamez1502
Banned
Nov 6, 2003
135
Lakeland Fl
Dec 1, 2004
  • Dec 1, 2004
how much would it cost for all this.
Joes95GT
3,132
Delaware
Dec 1, 2004
  • Dec 1, 2004
Many suggested something that I did not think of - 1.7:1 rockers and keep the stock cam. Scorpion rockers (IMO, the best and cheapest on the market) can be had from Ed Curtis at www.flowtechinduction.com for 200 bucks. You will need pedestal rockers - not stud mounted.
If you insist on the cam, I can't stress how bad the Ford racing cams are (as a whole). In this sport, you get what you pay for, and that includes camshafts. Yes, they are cheap, but keep in mind the results you will get are mediocre and the idle problems you will experience may make the car a real PITA to drive; stalling at red lights and such.
The long answer: It is my personal opinion that the stock valve springs are too weak for the STOCK cam, nonetheless an aftermarket cam with much more aggressive ramp rates and a potential higher operating range. Valve springs lose pressure over time. Lets pretend that in 94 or 95 the car's valve springs had pressures of 120# at the seat and 320# open. Imagine, 10 years and X-amount of miles later, what those pressures have diminished to. I would want a minimum of 135# at the seat and 340# of open pressure with ANY hydraulic camshaft.
The short answer: No. It's your engine. Is the extra 150 bucks saved really worth risking an engine? That decision is yours.
Joe
J
jamez1502
Banned
Nov 6, 2003
135
Lakeland Fl
Dec 1, 2004
#10
  • Dec 1, 2004
  • #10
thanks guys i think i will do the 1.7 rr and valve springs is there different kins of valve springs if so which one do i want. How do you order off this site. ANd also on the pedestal rockers will it say if its them
Joes95GT
3,132
Delaware
Dec 1, 2004
#11
  • Dec 1, 2004
  • #11
I like all of Comp's valvetrain stuff. Give them a call and speak to someone there. Choosing a valvespring is tough if you don't know what you are looking for and/or don't have the tools to measure.
Joe
J
jamez1502
Banned
Nov 6, 2003
135
Lakeland Fl
Dec 1, 2004
#12
  • Dec 1, 2004
  • #12
thanks joe you have been alot of help. i am new at the whole mustan world and dont know the first thing about building them. one more question with my current setpu shouldnt i be faster than 14.70s. that the fastest that it has been into off nitros. it went 12.60 with nitros
Joes95GT
3,132
Delaware
Dec 1, 2004
#13
  • Dec 1, 2004
  • #13
Yes, you should be faster than that. A lot faster. What were your 60' times? I'll bet you that is where it was lost.
Put the car on the GOOD sticky tire and the times will drop like you wouldn't believe. I would suggest an ET Street or ET Drag but then you are risking the rear-end of the car. Nitto and BFG's are a tough tire to conquer and take much more tuning and finesse to get your 60's down to where an ET Drag or ET Street would.
In fact, I would take the money set aside from the camshaft install and buy a set of 28-spline axles and a cheap pair of 5-lug 15" wheels and have a set of good sticky tires mounted on them.
Joe
J
jamez1502
Banned
Nov 6, 2003
135
Lakeland Fl
Dec 1, 2004
#14
  • Dec 1, 2004
  • #14
when my brother had thecar he was laucnhing on et drags with 175 shot of nitros i dont remember the time this is with launching at idle and easing out of the clutch then on one pass llaucnhed at 2000 and hardly any tire spin
stangboy
3,932
469
194
New Orleans, LA
Dec 1, 2004
#15
  • Dec 1, 2004
  • #15
I would suggest not getting the cam right now. You said you'll be getting heads this summer. Well, thats not too far away so just wait those few months. Also, if you get a cam that improves you current setup then that cam may not be enough cam for your new heads when you get them. Then you're gonna be buying a cam AGAIN. That's why I just stock-piled parts for my car for 3 years. Then I did EVERYTHING at the same time. I've been having my intake for 3 years...maybe even longer than that, and I got my cam from a friend for cheap, roller rockers for my b-day a couple of year ago, bought my headers from my old mechanic for dirt cheap. All that stuff sat around my house for a long time.....then I got the last thing I was waiting to get....my AFRs. Then I bought a rebuld kit and all the littel knick-knack part the do the rebuild and did everything at one time. It was long and agonizing but the wait paid off. Now my car was stuck at 14.3 at 99mph, I haven't been back to the track since I built the motor but I'm sure it'll turn better times when I go back.
Just give it some thought.
J
jamez1502
Banned
Nov 6, 2003
135
Lakeland Fl
Dec 1, 2004
#16
  • Dec 1, 2004
  • #16
also i forgot it has auburn locker and aluminum d/s
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Dec 1, 2004
#17
  • Dec 1, 2004
  • #17
Joe
ET Streets put the rear in danger? Who sells et streets for the best price?
Joes95GT
3,132
Delaware
Dec 1, 2004
#18
  • Dec 1, 2004
  • #18
An ET Street is nothing more than a drag slick with grooves in it, just wide enough to make it a DOT tire.
That is a bit of an oversimplification, but it's not far from the truth either. 8.8 rears are hit or miss. Some have bent axles on Nittos and others have been able to launch on nitrous with slicks for years. I wouldn't chance it.
Joe
GTJake
3,049
Ann Arbor, MI
Dec 2, 2004
#19
  • Dec 2, 2004
  • #19
Joe
I thought we sported 28 splines stock? Maybe look into some 31 splines? Or are you just saying, quick fix incase he breaks the stockers with some stickies?
Jake
Joes95GT
3,132
Delaware
Dec 2, 2004
#20
  • Dec 2, 2004
  • #20
Jake
I get too ahead of myself and don't think things through sometimes. (What else is new? ). I meant get a set of "strong" aftermarket 28 spline axles, that way he wouldn't have to change the posi and would have the strength of a good axle.
Joe
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Tuesday at 2:05 PM
Kleinjj27
K
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
