help on cooling fan???????
  • Thread starter Thread starter uggghdave
  • Start date Start date Apr 7, 2011
U
uggghdave
20
michigan
Apr 7, 2011
  • Apr 7, 2011
my 95 mustang gt cooling fan works but dont keep it cool. does the fan have dif speeds as it gets hotter? i got the car about amounth ago an some one hooked up a switch so i can turn the fan on high an it brings the temp down?
JJ95GTID
1,141
Phoenix, AZ
Apr 7, 2011
  • Apr 7, 2011
Yes, the fan has 2 speeds and comes on for different temps and also when the air conditioner is switched on. Not sure of the temps that trigger the different speeds but it has been discussed on here before.
SableSal
295
Fresno, Californ-I-A
Apr 7, 2011
  • Apr 7, 2011
I believe the low speed fan turns on at 212 and the high speed turns on at 221.
Hope that helps. If you have the AC on, the high speed is on at all times. Running the AC actually keeps my stang running cooler. lol
U
uggghdave
20
michigan
Apr 7, 2011
  • Apr 7, 2011
ok but the low speed comes on by its self! but some 1 wired up a switch so that the high speed would come on when you turn it on by a switch. i want to delete the switch an have it work like it should an come on by its self? any help would be nice?
JJ95GTID
1,141
Phoenix, AZ
Apr 7, 2011
  • Apr 7, 2011
Well, you are going to have to do some investigation to see how that person wired it up.
Here is a link to some wire diagrams to help you out.
https://sites.google.com/site/sn95mustangs/Diagrams
Good Luck!
HISSIN50
34
129
Apr 8, 2011
  • Apr 8, 2011
In case it helps:
94-95 Mustangs Cooling System Diagnostics - Mustang-Tech
In the body of the narrative, there's info about diagnostics/testing and wiring up fan switches (which might help you check the wiring or unwire them).
Good luck.
U
uggghdave
20
michigan
Apr 11, 2011
  • Apr 11, 2011
thanks guys for all ur help! but come to find out some 1 just hooked up the switch so they could control how hot they wanted it to run. low speed comes on at around 190-200 an high is around 210-220
HISSIN50
34
129
Apr 11, 2011
  • Apr 11, 2011
How did they modify the fan settings? Are you talking about an aftermarket fan controller?
U
uggghdave
20
michigan
Apr 11, 2011
  • Apr 11, 2011
they ran a wire from the grownd on battery to a switch in side car. then taped in too a wire coming from the ccrm to the switch the wire they tapped in too is green with purple strip. every thing works like normal but you can turn the fan on when you want!
HISSIN50
34
129
Apr 12, 2011
#10
  • Apr 12, 2011
  • #10
Your fan thresholds are lower than stock - that's the part I'm asking about.
U
uggghdave
20
michigan
Apr 12, 2011
#11
  • Apr 12, 2011
  • #11
sorry i dont under stand the ? thresholds?
HISSIN50
34
129
Apr 12, 2011
#12
  • Apr 12, 2011
  • #12
On a stock GT, low speed doesn't come on till ~208*F and high till ~226*F. Your temp for each seems to be lower and I wondered how that was happening.
U
uggghdave
20
michigan
Apr 12, 2011
#13
  • Apr 12, 2011
  • #13
maybe because it was dyno? can they change when it comes on?
HISSIN50
34
129
Apr 12, 2011
#14
  • Apr 12, 2011
  • #14
You have a custom tune (chip)? If so, that's possible
U
uggghdave
20
michigan
Apr 13, 2011
#15
  • Apr 13, 2011
  • #15
ya custom chip by lidio in michigan that guy realy knows what hes doing!
W
2.3l cooling fan questions
  • waxman
  • Jun 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 27, 2026
AeroCoupe
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
F
AC Compressor Power & Contour Fans
  • Fri Guy
  • Aug 27, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 15, 2026
BoostedRed89gt
M
cooling fan not turning on, but does when ac is on or when coolant temp is jumped or unplugged.
  • Mycarhatesme
  • Mar 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 12, 2026
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
