Help on ignition setup.
  • Thread starter Thread starter SHOJOE
  • Start date Start date Jun 25, 2009
SHOJOE
20
Maryland
Jun 25, 2009
  • Jun 25, 2009
Okay looking to rebuild my ignition system. My car is a 1985 Gt roller 306. I was thinking of :
MSD6 Al Box
MSD Blaster 2 Coil
FRPP Wires
Where I get confused is with the dizzy. Do I just get a factory vacccum advance or shoould I buy the MSD mechanical?
SHOJOE
20
Maryland
Jun 26, 2009
  • Jun 26, 2009
No one?
rd
3,316
63
109
Ocean Springs MS
Jun 26, 2009
  • Jun 26, 2009
I have an MSD Digital 6 on my 82. I am currently using the distributor to trigger the box directly and have removed the Duraspark box. I bought the MSD harness that plugs into the dist plug. I have Taylor Spiro Pro wires.
I originally set it up using the Duraspark box to trigger the MSD, but decided to simplify. Not sure if you can trigger a 6 AL directly from the dist or if you need the Duraspark box. The directions should tell you, otherwise call MSD.
I am using the plain old Duraspark Dist, with the stock mechanical and vacuum advance and it works fine. I currently have the vac disconnected, but it works fine when I want to hook it up for street driving. I would stay with the Ford unit until you want to spend the xtra money for the MSD. That said, I would like to get one with a fully electronic advance setup vice the mechanical and vacuum stuff.
If you use the stock dist, the mechanical and vacuum advance should work just as well as stock, and you do not change them at all.
rscapri30682
Three Rivers, Michigan
Jun 26, 2009
  • Jun 26, 2009
I've been using a 6al box, blaster 2 coil and duraspark box for years and with no trouble.
If I remember correctly, use the purple and green wires off the box. The green wire goes to the black/orange wire on the distributor, and the purple wire to the black/violet wire. Don't use the white.
They make a adapter so you don't have to any splicing.
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Jun 26, 2009
  • Jun 26, 2009
Is there something wrong with your ignition?
The msd stuff will do absolutely nothing for performance, i'd make sure all stock parts are in good working order and if so, just leave them alone.
If they aren't, the most reliable ignition parts are ford motorcraft.
If you need new wires, just get the ford racing set.
SHOJOE
20
Maryland
Jun 26, 2009
  • Jun 26, 2009
I thought the MSD6al would replace the duraspark box completely? So I am better of just sticking with the factory ignition components?
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
J
5.0 ignition wiring help
  • Jetscat7
  • Nov 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 25, 2025
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
