The 89 wiring harness is plug and play with an 89-93 5.0 Mustang computer.
Be sure to use a O2 sensor wiring harness that matches the transmission you now have installed in the car. If you don't you may damage the computer. I would advise you do do a search on O2 sensor harness in the 5.0 forum so that you can make the correct choice.
The Mass Air computers from 89-93 are interchangeable with a few exceptions. Just be sure you use the MAF & MAF sensor from the same series computer. The auto transmission computers use a different start circuit than the manual computers. You can use an auto trans computer in a 5 speed car with no problems or changes.I have done it in my original 89 Mustang GT, and I know it works OK. I have no positive input or com ments on using a 5 speed computer in an auto trans car. I personally would not do it.
The odd duck is the 93 Cobra computer, labled X3Z which is interally calibrated for 24 lb injectors. Try and avoid it if you can.
All the following are mass air unless they say Speed Density
8LD - MANUAL 88 5.0L Mustang Speed Density
8LF - Auto 88 5.0L Mustang Speed Density
A9L - 89-93 5.0L Mustang 5-spd
A3M - 93 5.0L Mustang 5-spd
A3M1 - 93 5.0L Mustang 5-spd
X3Z - 93 5.0L Cobra 5-spd
A9P - 89-93 5.0L Mustang Auto
A9S - 88-93 5.0L Mustang California
C3W - 89-93 5.0L Mustang Auto
DA1 - 87 5.0L Mustang 5-spd Speed Density
J4J1 - 94-95 5.0L SVT Cobra 5-spd
T4M0 - 94-95 5.0L GT Vert 5-spd
U4P0 - 94-95 5.0L GT Auto
W4H0 - 94-95 5.0L GT
ZA0 - 95 Cobra R
D9S - Lincoln LSC
