Hi I have a 67 Mustang Coupe with a 289 in it, a Edelbrock Carburetor 4bbl. Well the problem is my car overheats Ive changed the radiator I have taken the thermostat out (it dosent have a thermostat right now) but as soon as I hit the freeway it starts to heat up still. Ive checked compression and on all 8 cylinders it was fine. But I did notice that when I took my spark plugs out they were all filled with fuel, so I know its running rich. I want to try and change the timing because I also think its incorrect and I know that dosent help the rich conditon. I looked at the shaft for numbers but theres nothing there,theres only a bunch of white lines. I really dont know how to change timing in the first place, Im a learning mechanic. I was told the correct timng is 12 while I disconnect the dist. vaccum hose. Is that correct? How do I change the timing, and how do I tune my carb. If I fix this two problems will my car stop overheating? Cause Ive checked everything and it seems to be a big mystery and I want my car back running with a thermostat on too. This problems appeared when my ignition coil went bad and I was stubborn that the problem was the dist. cause the coil had a good amount of spark it seemed like. So I change the point and the condenser but it would not start so I bought a whole new dist. and thats when all these problems starded to happen when I was putting the rotor back in position and my timing went bad and my carb seemed really rich cause it was at really high idle. By the way the dist. was not the problem it was the ignition coil it actually did not have enough power, cause it had spark but not enough. My friend seemed to fix the timing and the rich carb but ever since then my car starded to overheat. I want to do it myself and actually get everything correct so please HELP!!!By the way I can tell my car is overheating by the factory gauge, it goes pretty much all the way up, if its on a no stop driving situation such as a freeway, but when its on the streets with a go/stop situation the gauge kind of sits at half, unless I accelelarate alot then the temperature goes to the roof but it comes down slowly as soon as I get a red traffic light.(it dosent come down right away though, it takes some traffic stops and me going more at a steady pace then it will begin to go back towards half). I really want to get my stang up and running ones again!!! THANK YOU FOR READING ALL THIS I REALLY APPRECIATE ALL YOUR OPINIONS AND YOUR HELP, THANK YOU!!!!
And these are the timing specs i got at auto zone is this correct?
Timing Specification:
For your 1967 Ford Mustang:
Timing Specification 12 Degrees
BEFORE TOP DEAD CENTER
*SET AT WARM IDLE SPEED (650 RPM)
*DISTRIBUTOR VACUUMHOSE DISCONNECTED & PLUGGED
*ALL ACCESSORIES OFF
*TRANSMISSION IN DRIVE (PARKING BRAKE ENGAGED)
