HELP PLEASE....installed 89 tilt colum in my 90
Tolbert67
70
3 Questions
1.Why do you think the entire colum, steering wheel ect.......is favoring to the left....it was alot worse but I losened the four bolts under the dash while my nieghbor pulled on the steering wheel (from the passengers seat) as I then tightened the bolts........it help quit a bit.....But still favoring the left a little bit....and now the shroud has a gap in it on the left side....... ???WHAT DO I DO NOW
2. I have one three wire connector(car end) left over and two connectors, two wire (steering colum end.."these two" both have a black wire)...are they the horn and cruise.....Ive "twisted them together in every possible senario.........my blinkers work, my wippers work,.....WHAT THE HECK ARE THEY AND WHAT SHOULD I DO??
3.How do I get the airbag light to go OFF:bang:
Wassup Tolbert,
1. There are two brackets (one that turns around and around which is the front one) mounted on the steering rack itself that bolts to pedal assembly. You will need to unbolt all 4 nuts and spin the mount closest to you 180 degrees. Than remount. You will see that the mounts are offset.
2. Yep on the 90 up cars you have airbag connector and than different cruise control connectors. Go to Autozone's website and download the wiring diagrams and you should be able to piece them together using one or other connectors.
3. Pull the instrument cluster out (while everything is apart) and pull the bulb for it. If you have trouble finding it, it should be under the RPM gauge to the right. Pull bulbs one at a time and shine flashlight in it in a dark room.
Enjoy your tilt steering!
the tilt colum question...#1
The upper bracket (the one that spins around and around)......It's in the same "spined" position the previous bracket was in.....you know, the airbag colum one..........But are you saying to spin it around so the shorter side "goes in" where the longer side was...and vise versa...????????????
.......I really appreciate your input
Wassup Tolbert,
i thought pulling the bulb will just set a tone instead?
