help please
urdogb8
35
Phoenix, AZ
I have a problem with my 1995 ford mustang v6. When i turn off the car it turns off. But when i turn it back on it wont turn over and theres no clicking sound. If i wait like 10 to 20 minutes, it starts back it. Is it the starting that going out?
Thanks
Aeroman
57
You could have a bad battery connection or a loose starter circuit cable or wire connector, only takes one loose or corroded connection to give all kinds of problems! Check all connections are clean & tight & we will go on from there. Also make sure the battery is in good shape, get it load tested where you get your oil changed.
wmburns
SN Certified Technician
Aug 14, 2009
5,894
521
204
Houston Texas
Sounds like the starter is overheating. After a while, the starter cools down and works.
Are there any heat sheilds that have been removed? Exhaust leaks?
Consider getting a new starter.
