Help plz vortech guys car boging bad below 3k
stanggt00
371
baltimore md
ok i reinstall my vortech flashed the tune on it
car was driving and idling fine
toke it for a nice hard run then the car starts to fell as if its boging under load below 3k just before the blower kicks in
no idea why its doing this there are no vacum leaks that i can see every thing is install correctly there are no oil leaks
another example from a light if you give it gas as if your tring to spin tires the car bogs bad when the pedal is pressed rpms ever raise slow
i was thinking it was the clutch but the motor is not spinning freely its almost as if its resisting accleration
Probably fouled the plugs. Pull them out and have a looksey, my bet is they are wet. Most likely the tune was so rich it saturated the plugs with gas. Also, might wanna check coil packs if the plugs look ok.
Also, depending on your setup (is it just stock vortech setup, or custom-ish?) you could be backwashing the maf (I've had that problem with my intercooled setup), also how did you mount the IAT sensor, you might have a leak there or have blown it out.
thxs again for the help guys
i found out the problem i like to call it tech error
when i was figthing to get the anderson power pipe on i had to lossen up the clap that was going from the supercharger to the first rubber hose
well i never clampped it back down so when i was going to check the maf i noticed that the intake hose :eek: was not even connected to the supercharger
reclamped it down and toke her for a spin all i can say is if your not blowing your not driving :nice:
