Help- Problems with my 67's electrical system
  • Thread starter Thread starter isfn13
  • Start date Start date Dec 2, 2004
I
isfn13
  • Dec 2, 2004
I have recently rebuilt my 289 small block and it has run fine except for the last few months. Somehow I have a ground in the system that is not allowing the battery to charge fully. I have replaced my alternator, voltage regulator, and tested my battery none of the above is the problem. If anyone has any answers that might be beneficial or needs anymore information that might narrow down the problem i would be very grateful. You can reach me at Patrick_Harkin2002@yahoo.com (by the way it is a 1967 coupe with pretty much all stock parts)
Thanks,
isfn13
2nd Mustang
2,488
Southern California
Dec 2, 2004
  • Dec 2, 2004
Get Car Craft magazine, January 2005 issue. It has a detailed article about finding that electrical gremlin.
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Dec 3, 2004
  • Dec 3, 2004
Thanks,
isfn13
what is your actual problem with the system?
battery wont charge?
battery goes dead?
cranks slow?
Pakrat
3,843
Currently: NH Originally: Rhode Island (and all po
Dec 3, 2004
  • Dec 3, 2004
Get the right tools for the right job regardless of the particular problem. Instead of buying and replacing parts, spend a few dollars on a decent multi tester that will allow you to isolate the bad area. It will also come in handy for adjusting points dwell and monitoring rpms when adjusting the timing amongst various other common and frquent maintanence issues.
2nd Mustang
2,488
Southern California
Dec 3, 2004
  • Dec 3, 2004
If/when you get a voltmeter, take the advice of the Car Craft article and get one that has a 10 amp capacity reading with a replaceable fuse. A digital model is the best as a few tenths of a volt could make a difference in trouble shooting. The other possibility is that the battery cables could be bad. Sometimes the cable could look good and have good continuity end to end but not enough capacity to carry the full amperage. Sometimes you can tell if the cable gets hot to the touch when the alternator is trying to charge the battery, but becareful, if the cable is leaking, you'll get a serious injury, don't ground yourself to the car.
krash kendall
1,258
Aldergrove, B.C. Canada
Dec 3, 2004
  • Dec 3, 2004
Here's a link to some wiring diagrams that may help you. I printed off all the ones applicable to my car and added them to a reference binder I've been making up.
Diagrams 1964 1/2 - 1967
SBF rebuild with no oil pressure NEED HELP
  • Falcon67
  • May 27, 2025
1965 - 1973 Classic Mustangs -General/Talk- May 27, 2025
horse sence
G
Resolved Please help! (starting issue)
  • Ghoste
  • May 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2025
Ghoste
G
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
J
98 GT Alternator will not charge battery.
  • johnsadler05
  • Jul 13, 2024
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 10, 2024
johnsadler05
J
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
