Help! Question about strut tower mount & Eibach dampers
  • Thread starter Thread starter MustangLX-5.0
  • Start date Start date Nov 28, 2008
MustangLX-5.0
856
Lehigh Acres Fla.
Nov 28, 2008
  • Nov 28, 2008
This being on my 92.I installed the Eibach pro kit springs & dampers on the front end quite awhile back.The car is far from driveable.I used stock strut tower mounts & bushings with the dampers.I heard from a few of you back then that it would work fine.
Well something doesn't work.That nut on the center of the strut clamshell doesn't screw down that far.So being that the threads dont stick out the top part of the nut.It hits the spacer that fits inside the bushing after a few turns.Am I making any sence to you?
I'm also having another problem which may or may not be related to this.After installing both the springs and struts,there's a problem with the sway bar end links.I'll jack the control arm up,mount the links into the arm,then onto the sway bar.The real problem,letting the control arm down more than a quarter and it starts pulling so hard on the sway bar links.I have to stop..it WILL either shred them or bust the sway bar mounts.
So I tried this with the extra long stock end links....even with the stock sway bar...STILL THE SAME THING.Its like the control arms go down a lot more than normal.
What's going on here? I totally stopped working on this car for nearly 10 months.I just need a 100% "for sure" answer so I can finish this thing and get it back on the road.
Maryland Stang
1,656
30
39
Greenville, NC
Nov 29, 2008
  • Nov 29, 2008
After reading your entire post I'm starting to wonder if you have the correct strut. What is the part number?
MustangLX-5.0
856
Lehigh Acres Fla.
Nov 29, 2008
  • Nov 29, 2008
Will have to wait till I get home.Unforunately I'm at work today.
It's for a 92 5.0 LX Convertible.I might try searching the threads because I posted about this nearly a year ago with no luck.Part numbers included in thread,if I find it.
MustangLX-5.0
856
Lehigh Acres Fla.
Nov 29, 2008
  • Nov 29, 2008
Part number on Pro Damper
3514.8001
That's directly off the strut.
Maryland Stang
1,656
30
39
Greenville, NC
Nov 30, 2008
  • Nov 30, 2008
I can't find that number anywhere. Did you look at the top of the shaft where the threads are and make sure there wasn't a sleeve or somthing there? All I can say is call Eibach. They should be able to resolve this over the phone pretty easily.
MustangLX-5.0
856
Lehigh Acres Fla.
Nov 30, 2008
  • Nov 30, 2008
Couldn't find that number myself.I just found the install sheet.Here's the info listed.
Pro-Damper Kit - #3514.840
Ford, Mustang - V-8, V-6, I-4, 1979-2002 (Except SVO, Cobra and Cobra "R")
Front Damper 3514.8001
Rear Damper 3514.8002
The rest is just bushings,washers and bumpstops etc.
Maybe someone can make sense of all this.It appears to be the correct kit.The only "sleeve" that's installed is the one on the very top of the strut rod at the strut tower.This is a spacer that goes to the factory mounts so the nut has something to tighten against.
Maryland Stang
1,656
30
39
Greenville, NC
Nov 30, 2008
  • Nov 30, 2008
Can you remove the sleeve? Did you try it without the sleeve. Can you trim the sleeve to a shorter length?
MustangLX-5.0
856
Lehigh Acres Fla.
Nov 30, 2008
  • Nov 30, 2008
The kit comes with 2 upper strut spacers and 4 lower mount spacers.The lower ones are thin pieces of metal.The uppers...I guess are these 2 sleeves or (spacers).They are the same diameter as the factory ones only 1/4 the length.
The kit only says to use these upper spacers if needed.It doesn't say where they actually go.
I don't know if your familiar with Eibach damper kits or upper strut mounts.I will list the assembly of an upper mount just for verification purposes.
Strut rod passes through strut tower - Bump stop fits on rod first - Then lower clamshell body of strut mount is placed on next - "sleeve" is next inserted (about 2" long) - Insert bushing (has hole in center of bushing so it fits into sleeve and fits lower mount clamshel half) - Upper clamshell with hole is inserted on top (this sits over bushing and sleve) - Nut inserted onto rod and tightened against clamshell (have to clamp rod with vice to prevent from turning).
The upper clamshell must meet against the sleeve to tighten the whole assembly properly.The sleeve is the same exact length as the bushing.Using the Eibach sleeve or none at all would allow the bushing freeplay and wobble.
I've been doing every bit of work to this car.I have no outside help except for SN.
I seriously appreciate your help this far.
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Suspension Foxbody ride height change after installing new control arms
  • Mhalc1
  • Jan 3, 2024
9K
Fox 5.0 Mustang Tech May 10, 2024
Mhalc1
